Internal seat problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2006, 03:54 AM
BMM BMM is offline
Hello. I just bought a 1991 Mustang. Near the bottom of the back of the passenger front seat, it feels as if there were a metal plate that was kicked in, jabbing your back. I cant feel an obvious 'bend' or 'dent' in a 'plate', but something is definetly odd. It is about 5 inches from the top of the seat bottom, and center/center-left.
Just wondering if you guys have any advice on what this could be, and how I could go about fixing it. Thank you!
Old 12-12-2006, 02:39 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Does this seat have a manual lumbar support in it? If that broke,that could be it. A broken spring could do this if it broke and twisted forward somehow. In any case, you'll have to open up the seat to find out anyway.
Old 12-12-2006, 03:32 PM
BMM BMM is offline
Can I open it up withou ruining the seay upholstery? Or am I dreaming
Thanks.
Old 12-12-2006, 06:28 PM
Wiki Edits: 22
Sure you can open it up without ruining it. They had to put it together in the first place, so you just reverse their steps. Do you know how to take the top section off the seat base? I'm not sure of the exact arrangement on this particular car, but the car's a two door, so the seat folds forward. Take whatever plastic trim there is off the door side of the seat and you should see a large bolted in stud that has either an allen head or a torx head in the end. Unscrew that. Normally the inside has a hole that goes over a stud, or a stud that goes into a hole. Lift up from the door side until the metal mechanism can clear the bottom seat. Push towards the driver's seat and the top of the seat should come right off. Look on the bottom of the seat top and see if it's held together with two interlocking plastic strips (one side may look like a "J" and the other side like an arrowhead) or hog rings between two wires sewn in on the front and back sides. Take this apart and you should be able to peel the seat cover fabric straight up far enough to see what the problem is. If the seat is broken beyond repair, find a donor seat, replace the donor seat cover with your seat cover, and reverse your steps to re-install the seat top. Be very careful, and document where any screws or other fasteners go as you're taking it apart. Good luck.
Old 12-13-2006, 02:05 AM
BMM BMM is offline
Excellent. Thank you very much for the info and help. Now, too find the time...
Old 12-13-2006, 05:09 AM
Trim Tech's Avatar
The Mustangs seat backrest have a two peace frame that were spot welded together and they have lots of support on the recliner side but on the inside where they pivot they lacked support. Does the seat lean back to the inside (right) or twist when you push back on the seat? If you can see the seat flex I would bet money on it you have slit the spot welds. This is an easy fix remove the cover as Dan said and then split the frame from the cushion frame, place a 2x4 on the ground then place the backrest frame over the 2x4 on a corner to corner and stand on the seat to flex the frame straight again. Once you have the frame so it will lie flat on the floor we weld the center opening a complete bead not spots to give support also on each side there is a supported area that the recliner bolts to weld this as well both sides for strength. If all else fails post pics!
Jason
Old 12-15-2006, 01:34 AM
BMM BMM is offline
Hello.
No,the seat doesnt lean to tilt one way if I apply pressure, it just goes straight back abit. It is confusing me as I can not feel anything in the seat back until I hit the part that actually is poking out.
The springs are pretty worn, so I may just find a donor seat.
Thank you.
blower idle rpm problem Ratoflic Engine 7 12-01-2008 04:31 AM
Not sure how to tackle seat mount problem jemo Interior 7 10-29-2006 05:22 PM
Puzzling temperature problem on the hemi solved Centerline Engine 2 11-26-2004 04:48 PM
Internal vs External Balance 614streets Engine 3 05-28-2003 02:25 PM
seat upholstery dh79 Interior 2 04-09-2003 05:44 PM
