-   Hotrodders' Lounge (http://www.hotrodders.com/forum/hotrodders-lounge/)
-   -   International 4-Door Panel... (http://www.hotrodders.com/forum/international-4-door-panel-59067.html)
Crankshaft 03-02-2005 11:10 PM
Hey All,
New here. This is my first post, so be gentle please.
I've come across an old International panel truck, its a 4 door version. Being the fact that I know mostly old Fords, I don't know where to start on learning about this animal. I've already done a few searches here and have learned some things -- like the 'corn binder' nickname -- but I was wondering if you folks could point me in some specific directions.
Such as what engine this truck has in it. Its a V8, backed by a 4 speed transmission. Also, is it possible this truck could be a 3/4 ton? Looked like it might have had a Dana 60 rear end, but I'm not real good on visually indentifying differentials.
Are there any International specific websites out there? I know the 'net is covered up with Ford stuff, and know where to go to find something about a Ford, but this International has me scratching my noggin wondering where to begin.
Thanks all.
-Crankshaft
WakBordr7387 03-02-2005 11:42 PM
Welcome the board! :thumbup: For websites and that kind of stuff you might want to check out the Knowledge Base, its the link at the top of your screen. It has all kinds of websites, you might find what your looking for there. If not then I'm sure someone on this forum knows a few.
Brad
OneMoreTime 03-03-2005 12:22 AM
Corn Binders
International built their own engines..They are good solid very durable perfomers but not a lot out there in performance pieces..What we term a 3/4 has the 8 stud wheels on it and probably the old split rims if yours is older..
They are not a real popular piece but could make a nice odd rod if nicely done..Paint and interior and such..
Hve a good one
OMT
BOBCRMAN@aol.com 03-03-2005 05:31 AM
I am a past "Binder" owner. A 57 four door short bed pickup. Even the 1/2 tons were built like the other manufacturers 3/4 tonners. The 3/4-1 ton had the eight bolt wheels. Try www.Binderbulletin.org/
CrashFarmer2 03-03-2005 09:40 AM
Could be a 304, 345 or a 392 V8. Do you know what year it is?
Does it look like the pickup in the picture below?
http://hotrodders.com/gallery/data/5...Hfrtdr-med.jpg
Hippie 03-03-2005 09:52 AM
I haven't seen one of those in years but the CB & Q RR used to have quite a few of them back in the 60's. If the body is good I'd swap in a newer more common drivetrain. The IHC V-8's were dependable as heck but parts weren't cheap even when they were still in production. I used to work for an IH dealer and WE didn't even get a discount on them! It would make a really cool "Odd Rod" like said earlier.
Crankshaft 03-03-2005 04:50 PM
No, its got fat fenders like a mid-50s Ford. I was looking on oldtruck.com and found a couple of pics. I believe this one may be around a '56 model. Its got the 4 doors as I previously mentioned, and the floor of the truck behind the rear seats is wooden. Its also got solid sides with an oval window set at an angle.
Thank you for the link to BinderBulletin BOBCRMAN, I'll be registering and doing some research there shortly.
I look forward to getting into this project, once I get the truck home. Hopefully it'll get a big block and be made into a tow rig. :thumbup:
-Crankshaft
speede5 03-03-2005 07:57 PM
http://www.oldihc.org/
Lots of great info here. I think you are looking at what they called a Travelall. Kinda like a Suburban. I have a 1965 and 66 IH 1/2 ton trucks which I will be turning into one truck this coming winter. Really pretty cool trucks but parts can be quite difficult to find. Get ready to use some hotrodder injinuity!
Cheers
Crankshaft 03-03-2005 09:23 PM
Originally Posted by speede5
http://www.oldihc.org/ Lots of great info here. I think you are looking at what they called a Travelall.
Another good link, thanks! :thumbup: And yes, a search on Google for Travelall turned up images of trucks very similar to what I've found.
This one is close, but like I said, the sides of the one I found are solid with just a small oval window in the side.
http://isaac.healdsburg.net/travelal...all%20Rear.jpg
CrashFarmer2 03-05-2005 08:27 PM
-Crankshaft
OK, does it look like the one in this picture, I the front anyhow. this is a picture of my brother's 1956 IH shortbox taken today, 03/05/2005. That is my brother leaning on his 69 1/2 Ford Maverick. Yes, that is a 75 big bumper front end. also visible in the picture is his Cougar and one of his Turbo Coupes.
http://www.awsomecar.com/pix/56IH.jpg
The Gallery must not be working since I had to post this picture to one of my web pages.
willowbilly3 03-06-2005 06:20 AM
Also note that the 3/4 ton internationals through at least 1968 did not have 8 hole wheels but a latge 6 bolt pattern.
