international inline - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2005, 06:31 PM
New Member
A guy I work with found and purchased a 1954 International RV. It's a converted school bus from what I can tell. My question is can anyone send me a brief description of the inline six engine that is in the bus. Before I saw it (the bus) I'd guessed it might be a 225 Chizzler but it's definatly larger than that...I mean tractor material. Also it's cupped up to a 4 speed manual (looks similar to a modern allison) with 2 gear sets like an old Ford farm tractor. Bear with me here I'm pretty virgin to this old school heavy equipment dealings and I'm only 25 years old.
Old 02-01-2005, 06:46 PM
BOBCRMAN@aol.com's Avatar
International built em tuff/heavy. The engine is "Binder" made. The trans probably a Clark.. I know for a fact that a big block Chevy with 400 turbo weighs several hundred pounds less than that six with manual..
Old 02-01-2005, 07:23 PM
New Member
Any ideas on displacement? Looking for "Brine" related engine searches on the web yeilds no results.
Old 02-01-2005, 07:35 PM
Most likely it's a 262 ci. International made bigger ones all the way up to 501 ci. I have a fresh 57 262 on a stand, waiting for a new home, factory reman.
Old 02-01-2005, 09:17 PM
Try www.oldihc.org Lots of Inter binder stuff!
Old 02-02-2005, 12:02 PM
Dave E Shank's Avatar
HEY BOX:
You might try www.inliners.org lots of old sixers there...DAVE
Old 02-02-2005, 05:46 PM
Rebuild Watchout
Back in the early 70's I had a Binder six
I transplanted into an Army 6x6.
It was a little small for the job, came out of like a ton & 1/2, or 2 ton truck at the most.
Nontheless, HECK of a stout, torquey motor. Rebuilt it and it ran real strong for what it was. I think it came out of maybe an early 60's, and seem to remember it was a 264.
I was told by somebody that used to work for a road contractor that when rebuilding those things, put in NEW valves, don't grind the old ones. Well, I didn't have the cash, so ground the old ones. Sure enuf, after a couple months of really hard use pulling that heavy deuce & 1/2 around off road, with a 7 yard dump box on it, a head came off of one of the valves at "high" rpm (I had a straight stack on it like
an 18 wheeler, no muffler, MAN did it rap nice! You could hear it for 1/2 mile when it was under heavy throttle)
THAT didn't do the piston & cylinder
any good!
Old 02-02-2005, 06:36 PM
New Member
Well I'm just going to jump into it and mic the bores once I get it apart. He definatly wadded up a connecting rod (literally...looks like chewed gum). In any case thanks for the replies and tips. I was able to find a shop online, in the San Diego area, that will assist me in finding parts.
The stacks exhaust might be rad though!
Old 02-02-2005, 09:38 PM
The term "Black Diamond" comes to mind now that I think of that engine some more.
Also, the next bigger one (like 308 or something like that) may have been called Red Diamond ???
