Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Intrepid power steering pump
Old 12-09-2009, 11:36 AM
oldguy829's Avatar
oldguy829 oldguy829 is offline
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
Heard a rumor, "the dodge intrepid power steering pump is identical to the gm pump on the LT1, except for a remote reservoir".
Anyone actually done this? It may be a handy solution in some tight spots.
Also, where can I find some specs on the dodge pump vs the GM pump? PSI, flow rate etc?
Thanks for any help.
