Intrepid power steering pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-09-2009, 11:36 AM
oldguy829's Avatar
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
Heard a rumor, "the dodge intrepid power steering pump is identical to the gm pump on the LT1, except for a remote reservoir".
Anyone actually done this? It may be a handy solution in some tight spots.
Also, where can I find some specs on the dodge pump vs the GM pump? PSI, flow rate etc?
Thanks for any help.
Old 12-09-2009, 11:45 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
It would be a real bonus if the pulley size was 5" or less so the pump pulley would clear better in swap applications. Even if the pulley from the MOPAR would fit the GM pump...
Old 12-09-2009, 12:04 PM
Saginaw power steering pumps are used on LOTS of cars, not just GMs. The basic pump is the same, just the reservoirs are different.
Power steering pump on blown motor Marcus Engine 14 05-16-2008 02:10 AM
1971 chevy 350 power steering pump colincamaro Suspension - Brakes - Steering 10 12-27-2006 02:14 AM
power steering pump question 46 chevy pickup Suspension - Brakes - Steering 7 08-25-2006 08:05 PM
power steering from long water pump to short water pump kellyem Suspension - Brakes - Steering 7 02-22-2004 08:22 PM
power steering pump impala dreaming Suspension - Brakes - Steering 3 02-15-2003 06:00 PM
