intrument panel 83 ford pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2011, 01:08 PM
how do you disconnect the speedo etc from it to remove, i need to hook up the gear selector device
Old 01-03-2011, 05:34 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
If i remember correct it has a clip you will have to reach in and squeeze it and pull it loose. If not then it should un-screw. JMO
Cole
Old 01-03-2011, 07:35 PM
Here's a picture of the connector at the back of the speedo.
36 Ford Pickup on a Ford Ranger Frame? Fasteddy General Rodding Tech 21 12-08-2012 11:25 AM
48 Ford Panel Van Mr Rob Body - Exterior 1 04-20-2006 06:09 PM
1934 Ford Pickup Patch Panel Gauge? JimG Body - Exterior 2 04-16-2005 08:10 AM
Intrument Cluster draft Electrical 3 08-20-2004 06:24 PM
1932 Ford Pickup and 1933-34 Pickup Different? YES pasadenahotrod Transmission - Rearend 1 10-23-2002 02:20 PM
