Investigating Accusumps - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-16-2013, 10:18 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
Still wondering with say a 7qt wet sump pan where I could plum it into the block??.
Also where I can get a adjustable oil pressure switch to wire it with a electric valve??.Maybe also use the adjustable switch to work as a low or no oil pressure shut down??.Kind of say the engine experiences a no oil pressure event,but the accusump adds oil to save parts/bearings.
  #17 (permalink)
Old 12-16-2013, 10:33 AM
Some time ago I considered one of the Accusump or equivalent of the other brand. However I found it much easier, useful, and convenient to just use an electric pump (tilton differential oil pump) plumbed with a weld-in AN fitting for input and a line to oil filter housing for output.
Much less room to find too (those accumulator designs can be quite large!). I also think those storage type are very limited and would only be good for a fraction of oiling backup. I also have my doubts about them possibly holding a full pressure charge over a long period.
With this pump system I can easily hit the manual switch before startup and oil as much as I want before startup. Other uses also possible but not ones that I need. Such as engage the pump if you want when oil pressure is at x psi or any other parameter desired.
For me it is the way to go to address pre-oiling.
I think this is the one I use
http://www.summitracing.com/parts/til-40-525/overview/
The Following 2 Users Say Thank You to Byronski For This Useful Post:
1Gary (12-16-2013), AutoGear (12-16-2013)
Investigating Strange Engine Sound horvath Engine 15 07-15-2003 09:56 AM
