you need different pistons. D shaped dish, forged, shoot for about 8:1 compression. Cam should be less than 225º duration at .050" on a wider LSA (112-114), and preferably hydraulic roller. lobe split depends on the turbos used, will probably end up around a single pattern or a small lobe split (6º or less).
I currently have a late model GM long block, ported vortec heads, roller cam 230/230* & 470/470, air gao intake.
It went 12.62 @110 in my vette on 87 octane, street tires and 3.07 posi here is a vid of the car with stock manifolds on it and a Q-jet http://www.youtube.com/watch?v=SAi2ablaEbM I have both headers made and an ebay turbo, y2004k (gt45 haha) It is close to 9.8:1 compression I think and with iron heads I'm not sure how much boost I will be able to push through it on pump gas and no intercooler (I do have an intercooler but I'm having fitment issues with it so.... unless I just have to have it I'm going to forget about it for now.) If you want to keep updated on it send me your email in a PM. |
scroll through those. That should get you a better idea of what pistons you have. But like ap said you will likely need forged. I am currently building a turbo 305 with stock cast pistons but I am running piston oil squirters and will be running 8.0:1 and an intercooler. So hopefully my pistons wont come apart too quickly. IMO i would never run a carb on a turbo engine. It would be so much easier to run fuel injection. More expensive but better in the long run. |
keep the boost low and cast pistons won't mind.. boost around 5-6 psi, assuming a comp ratio of 8.5:1 will be just fine, and should add ~100 hp
well i plan on getting new pistons. someone told me there are two kinds to choose from. i was just going to call up summit and see what they have. sounds like it comes down to low compression, forged lower end, and a cam like mentioned in the thread.
There are probably a bout a thousand different pistons that will fit that block... I guess by two you mean, the right kind, and the wrong kind? |
| Twin Turbo SBC build, need help | SBC S-10 | Engine | 27 | 04-21-2012 06:51 PM |
| involved q about building a sbc turbo motor | v8mazda | Engine | 13 | 06-12-2010 05:52 PM |
| I'm building a sbc 350 need input PLEASE | the ernster | Engine | 8 | 07-13-2005 01:56 PM |
| motor plates sbc / water pump | captainflyte | Engine | 2 | 11-03-2004 04:03 PM |
| turbo SBC ? / lingenfilter ? | x007 | Engine | 20 | 10-03-2004 01:55 PM |
