Iroc-Z - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2005, 09:37 PM
Iroc-Z fan
Iroc-Z
I was reciently looking to build a drag car. I have looked for a few different cars but the one that keeps stealing my attention it is a late 80s Camaro Iroc-Z. What classes would this car be legal for? This will NOT be driven on the street just on the track in Denver, Colorado. What all does this car have out of the factory? Thanks for any help you may offer.
Eric
Old 08-28-2005, 01:58 PM
LivenInTheFastLane's Avatar
Roasten Imports Old School way
Iroc-z
1985-1991
V8's
1985-1986
5.0 Carb 145 hp
L69 5.7 H.O. 190 hp
5.0 T.P.I. 215 hp
1987
5.0 Carb 165 hp
5.0 TPI 215 hp
IROC-Z 5.7 TPI 225 hp
1988
5.0 Carb 170 hp
5.0 TPI 215 hp
1989-1990
5.0 Carb 170 hp
5.0 TPI 215 hp
5.7 TPI 240 hp
1991-1992
5.0 Carb 170 hp
5.0 TPI 215 hp
5.7 TPI 245 hp
Tranny
Man.
4 speed
5 speed
Auto
700-R 4 speed overdive
Information provided by
*For more info, please visit www.musclecarclub.com
Old 08-28-2005, 09:24 PM
1982 SS's Avatar
Flamethrower
Last journal entry: More Cooling fan pictures.
I would rather race a G-body. They are lighter, stiffer and much easier to work with. Not t mention, the Malibu Racing guys are really quite fast without a lot of serious fram stiffening work. Just the F-41 stuff and an upper core support to firewall brace and they turn out real stiff. To me, looks don't go fast just put the power to the ground.
Just my opinion...
Old 08-29-2005, 07:40 PM
badknuckles's Avatar
you talkin to me?
isn't that the truth.
if your looking to turn a f body into a dragster you'll have some serious chasis problems. i would go with a g body as well.
if your set on a f body i wouldn't set my sites on an iroc. if your going to gut it and tear it up you might as well just get a regular camaro you'll find it cheaper and your going to have to gut it anyway (susp,drivetrain etc...)
Old 08-29-2005, 09:06 PM
Iroc-Z fan
What is the difference of the F-body and the G-body? What type of work would have to be done to stiffen the frame? What would have to be done just to make the car better?
I have been looking around and have a goal set on what I want the car to have when I am done including many and more of the following:
Full roll cage, frame strengthening.
Mark Williams Dana 60 rear end with a spool, high torque axles, 4 link rear end... etc.
5 speed manual transmission - high performance clutch along with a stronger balanced drive shaft (with loops)
383 Stroker.
Blower/turbo Camshaft
Roughly a 7:1-8:1 compression ratio
Dart heads
Currently unsure if I want to go with a Twin-turbo kit from Banks Performance or go with a Blower/Supercharger.
Custom headers and a dual 3.5 inch straight pipe exhaust.
Possibly Nitrous Oxide if needed
I plan to run the car on a racing gas or something upward of 115octane.
I'm looking for roughly 900+ horsepower if possible.
Also, would anyone know where to get a hold of the class specifications for the NHRA or is that in the rule book?
Thanks for the help anyone can offer,
Eric
Old 08-29-2005, 09:31 PM
BigDawgsEatFirst's Avatar
400SBC4Life
900 thats alot for a 383
use the best parts
Old 08-29-2005, 10:25 PM
1982 SS's Avatar
Flamethrower
The F-body is the Camaro Firebird and Teans Am (any year) and they are an oddly heavy car with poor frame strength.
The G-body is the 78-87 Malibu, El Camino, Monte Carlo, Regal, Grand National, Cutlass, Bonneville, 442. I think that's all of them. They are lighter than the F-body and stiffer than the F-body and the previous deacades A-Body. They already come with front disc brakes and can be had with the optional F-41 suspension package wich came with a stiffer front sway bar, a rear sway bar and Radiator core support to frame stiffeners. There are a lot of companies making stiffening parts for the G-body to make it even stiffer. Also, most people don't know that the El Camino actually has the best weight balance of all the cars mentioned above. It can be made to a perfect weight balance without a lot of effort and a little fiberglass.
If you are planning to make a drag car without a ton of cash, a G-body can be had for real cheap in good shape when compared to a similar F-Body.
Old 08-30-2005, 05:53 PM
Siggy_Freud's Avatar
I personally wouldn't build that engine unless I had the money to finish the forced induction setup right away. Wont be very peppy without the boost to compliment the setup.
That sounds like a VERY expensive idea (especially going with the Banks Twin turbo kit). Do you have the money or is this a 5-10 year type deal?
For one, Id seriously do some reading about forced induction as you can build a turbo kit for a FRACTION of the cost of what Banks wants for theirs. Secondly I'd seriously consider a Fuel Injection setup especially if you are going to go with a Turbo'd engine. You can make your HP goes out of a smallblock, its very possible. But it will require a lot of time and money, and with the amount of boost your going to have to run, you'll want ever precaution taken and many of those precautions can only be taken using a Fuel Injection setup.
Just some food for thought.
Bringing history and technology together.
Old 08-30-2005, 06:02 PM
pmeisel's Avatar
Glad the Jeep is on the road
Last wiki edit: How to identify a Ford V8
Eric
NHRA rulebook has all the class spec info. With all that you are considering you need to evaluate what class you would run -- of course you can bracket race with quite a wide variety of mods.
87 iroc rear disc brakes dont work camarofreek Suspension - Brakes - Steering 4 07-18-2005 11:10 PM
i need parts for my 85 iroc and i have no money help!!!!!!! LEGENDARY COMARO Introduce Yourself 2 01-13-2005 11:41 AM
iroc wheels fit on a 1980 TA? Trav Suspension - Brakes - Steering 3 12-18-2003 07:37 PM
85' Iroc blakblur Engine 3 10-30-2003 11:14 PM
