Iron Duke stroker kits? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2004, 08:42 PM
Grumpy
I'm sure I'll catch some flak for this one, but here it goes.
Do any of you out there know of any Iron Duke 2.5L stroker kits. I know it's a 4in bore x 3in stroke so I would think someone out there would have made one by now. Did a search and found no articles on it.
Thanks.
and yes this looks like another project coming my way when I have no more room as it is
Old 10-15-2004, 08:07 AM
coldknock's Avatar
Not too sure 'bout that one. Phord has the domestic 4-banger aftermarket with the 2000/2300 engines. Roundy round racers love 'em.
The only thing I remember was a SD verion of the Iron Duke from Pontiac. 175" I think it was. If you dig deep enough you might find a crankshaft in usable shape. You'll need some serious headwork done to take advantage of the extra cubes, or pay through the nose for a SD Pontiac head. If you can find one for sale.
Larry
Old 04-01-2006, 04:09 AM
My Interest On The 4
THERE ARE 4 INCH STROKES OUT THERE. 3.48 IS THE LONGEST IN THE BOOK i JUST LOOKED IN. i DID NOT SEE THE ROD LENGTH BUT YOU WILL DEFINETLY JERK THE ROD BOLTS APART. i DON'T HAVE ANY IDEA OF ROD LENGTH BUT RED LINE IS GOING TO BE LOW. AND YOU NEED THE SD BLOCK OR A TRUCK BLOCK. THE BOTTOM END IS REINFORCED IN THE CASTING.
Old 04-01-2006, 10:19 AM
TooSlow's Avatar
Beater Driver
There is a rabid following out there for the Pontiac Fiero, most of which were powered by the Iron Duke. Try posting your question in a Fiero forum and you might get more responses.
Old 04-01-2006, 12:23 PM
stroker
I found a 3.625 changeout in a SD Could not get a price though. I have looking in Fiero's myself. I want a 4 cyl also, is this it, and can I afford it. I have 6's and 8's but no 4's , Is the pontiac for me-I hope so but I don't know. I would ask if any one can recommend a 4 cyl for me. I like carb's- maybe 2x2 webers, but I have no restrictions, someone tell me what is the best 4 cyl for street sports car. Or even off road 4x4-good engine, I will put it in, except diesel obviously. highend one way, lowend the other. make some suggestions. mean while I dig for the strokers for you. I started a thread for my 4. mark
Old 04-01-2006, 12:38 PM
NorthStar's Avatar
Why waste time and money on the stroker kit?
I would spend it on a Brodix head and do whats neccessary to get good air flow.
http://www.gmgoodwrench.com/perfpart...Engine%20Parts
Old 04-01-2006, 12:56 PM
Race The Truck
Last journal entry: Son's Truck
There is a guy in Califorina that does all kinds of stuff for the Fiero And chevy Citation X-11 Which was used in scca racing and even Yenko was racing them back in the 79-80s I have a chevy artical on the racing, anyway check out there web site or give them a call there very help full.
www.westcoastfiero.com
Craig
Old 04-01-2006, 05:22 PM
A solution to raise cubes on this 151 is to install a 153 crankshaft.It will increase your stroke 1/4".Not much but cheap.I built one recently and had to machine the piston tops about 3 mm.Got 11,6:1 CR with stock head! Burning straight ethanol with a Solex carb and 8 degrees timing advance.Runs smooth.
Paulo
Old 04-02-2006, 05:30 PM
stroker vs Brodix
Sounds better to me, and my personal use but I don't know why the originator of this thread wanted inthe first place. I assume a stroker means you need the whole bottom end anyway. the Question is you did not have to change rods, just top off the pistons.WHATS YOUR AIR FLOW, WHATS YOUR TOP RPM WITHOUT THROUGHING A ROD. thx
Old 04-04-2006, 09:11 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
There are lots of four cylinder options out there, depending on what you want to do. Olds Quad Fours are great in light rods. For a more nostalgic look track down a Pontiac, International, or Ford "slant four" (literally 1/2 V-8 blocks, usually the right bank -- use the same head/pistons/rods and many other parts of the V-8s). Not many speed parts, but the header is easy and good used cams can be re-ground.
There was a thread here about Chevy and Ford marine fours. The blocks are made heavier due to the constant speed stress of marine engines. That's the only application for the Ford "slant four" -- it was never used in a land vehicle as far as I know. The Chevy marine four is based on the old Chevy four first used in the early Chevy II, IIRC.
Old 04-04-2006, 11:27 AM
FASTCHEVY's Avatar
RatRod B4 RatRods were Cool
"truck block" I would assume you are talking about an S-10 engine?
Old 04-04-2006, 12:36 PM
truck block-----slants
yep, thats about all I know on the subject. The old habits die hard, but Pontiacs history has never been toward the high end. Everybody jumped on the over cam-Pontiac did it thru Aussies, Brown and something,I think. Pontiac slant 4, Early 60's tempest half 389 all the way. International half of 345 v8,I have a couple v8s nothing to do with them but run in farm trucks and such.mark ps There used to be some good scout used parts and groups. I did not totally quit, butI am going to try to get out this year. I have 2 4x4's out there besides scouts I am looking for a engine-IRON DUKE ?
Old 04-04-2006, 06:05 PM
Hey guys.Was the original Pontiac Fiero cylinder head a cross-flow design?
Was it done in aluminum?
Paulo
Old 04-05-2006, 12:14 AM
crossflow
IRON DUKE CROSSFLOW MY book says no, would not take it for gospel though. Probably not by all counts , I am beginning to get enough material together to have realistic answers, but I am not well organized yet, but I went through a bit of listings,books,etc. mark
Old 04-05-2006, 08:13 AM
New Member
Kansas Racing Products, http://www.kansasracingproducts.com
An inline four cylinder block based on the Pontiac Superduty-4 engine. It will accept all of the Pontiac SD-4 components. Also, the block can be ordered to be finish-machined to accept virtually any smallblock V-8 cylinder head...GM, Ford or Mopar. Displacements from 140 cid to 213 cid...up to a four inch stroke crankshaft and 4.125 inch cylinder bore. Roller camshafts are supported by five journal roller bearings. Bellhousing parttern can be ordered to accept most common bellhousings.
A KRP engine has never suffered a block-related failure even under high boost conditions!!
