Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Iron Duke stroker kits?
Old 04-01-2006, 05:22 PM
paulo 1 paulo 1 is offline
A solution to raise cubes on this 151 is to install a 153 crankshaft.It will increase your stroke 1/4".Not much but cheap.I built one recently and had to machine the piston tops about 3 mm.Got 11,6:1 CR with stock head! Burning straight ethanol with a Solex carb and 8 degrees timing advance.Runs smooth.
