iron performance heads for SBC - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-27-2002, 06:32 PM
NAIRB's Avatar
Post
Hands down, the best flow per dollar available today is the Vortec iron cylinder head, these stockers rival many aftermarket racing heads in terms of flow, and they are almost half the price of a new set of Sportsman 2s, of course they are not as thick and heavy duty as a Sportsman, and they don't come with 2.02 1.600 sized valves, but you can make them a set of super flowing cylinder heads with the larger valves, and some valve guide reshaping and mild bowl work.
  #17 (permalink)
Old 09-28-2002, 08:30 AM
chevyelc81's Avatar
Post
I, personally, would rather have the aluminum heads. They lighten up your car alot and they transfer heat so much better. You have cooler air being brought into your engine, which makes more power. Cooler air has more density which means more air molecules are entering your engine. When it sparks, there is a more powerful explosion. The only problem is, if your sitting in traffic to long and your engine starts to run hot, you have more of a chance of cracking the heads, thats one advantage of cast iron heads, they dont crack easy. But anyways, im just putting in my 2 cents worth.
  #18 (permalink)
Old 09-28-2002, 11:25 AM
New Member
Post
[quote]Originally posted by NAIRB:
<strong>Hands down, the best flow per dollar available today is the Vortec iron cylinder head, these stockers rival many aftermarket racing heads in terms of flow, and they are almost half the price of a new set of Sportsman 2s, of course they are not as thick and heavy duty as a Sportsman, and they don't come with 2.02 1.600 sized valves, but you can make them a set of super flowing cylinder heads with the larger valves, and some valve guide reshaping and mild bowl work.</strong><hr></blockquote>
I have been told by my porting guy that the out of the box Vortec heads will need porting to get them to flow as good as stock ported iron heads. Thts is ported stocks are ebtter than out of the box so add some money for porting if you go with the Vortec.
Aluminum is better but I can alwasy do that later if the stock port job does not pan out.
  #19 (permalink)
Old 09-28-2002, 02:36 PM
NAIRB's Avatar
Post
The iron vortec head flows 230 cfm at .500" valve lift, box stock on the intake side, they flow around 150 cfm on the exhaust side. There is some improvement to be gained with porting, but not as much as you would gain with say a 186 style head. Your porting guy is wrong, these things flow very well just as they are, but there is some room for improvement.
  #20 (permalink)
Old 09-28-2002, 02:44 PM
NAIRB's Avatar
Post
Please note that the iron vortec head outflows the fastburn aluminum head on the intake side, out of the box, the exhaust flows better on the fast burn GM head, so if Vortecs are used, a little work is needed on the exhaust side. As far as aluminum is concerned, it's a great deal, but more costly, I think the biggest advantage to aluminum is it's repairability and weight savings. I don't think there is that big of an advantage in any other area, other than possibly heat dissipation advantages. You do have the problems associated with aluminum on cast iron, and the different expansion rates of the materials, and head gasket brinnelling. If I had unlimited money, I would go with aluminum heads of course. However, the real bargains out there are with the cast iron stuff.
  #21 (permalink)
Old 09-30-2002, 08:57 AM
Post
The Dart Iron Eagle heads are a great iron head for higher RPM applications. They can be had in 200, 215, & 230 cfm intake runner capacities, straight or angle plug, and down to 64cc combustion chambers. They do work better with open plenium intakes though. A lot of circle track racers use the heads where their class calls for iron heads only. Oh yeah, they are a good casting with lots of meat for additional porting.
  #22 (permalink)
Old 09-30-2002, 11:23 AM
F-1Rodder's Avatar
Post
I am a fan of the Vortec. All I have read (quite a bit) is that you should not touch them, no improvement will be realized. But this isn't about perfection, every engine is a compromise between torque and HP. This string started about price and power. If you know , tell me how you will get the power available from $430 Vortec's from any other source? With Vortec's you can build a 355 to 400hp plus for about $2000 including block, machine work,rotating assembly, heads, cam, rockers and carb.
  #23 (permalink)
Old 09-30-2002, 12:39 PM
Post
I have a 350 engine that has 10:1 pistons,medium lift cam and edelbrock perfomer intake.I was told the heads are so so.They are 69/70yr 350heads with 76cc chambers.Are they good or should I change valve size or go with something else
  #24 (permalink)
Old 02-23-2003, 06:23 PM
Post
Let's focus more on the bowl area...
How do the stock Vortec castings look in the bowl area? Do they really need to be touched here?
Any estimates as to power gains to be had here?
How does the choke diameter compare to the intake valve diameter?
  #25 (permalink)
Old 02-24-2003, 03:39 AM
New Member
Post
A company that makes two choices for heads..iron and aluminum is Pro Action, <a href="http://www.protopline.com" target="_blank">http://www.protopline.com</a> . Our sprint car team is allowed to use any 23 degree iron head ( rules change ) so we removed the GM "Bow Tie" heads in favor of pieces that have 210 cc runners. Cost per bare head is about $300.dollars each. For street use, I recommend iron over aluminum. More durable and they heat on a consistant basis when mated to an iron block. Fewer problems with corrosion too.
Important considerations about heads regards their application. Very few cars...even race cars are at full-throttle all the time. Look at the mid-range flow numbers instead of high end total cfm. If you lose velocity by having too big of runners then your fuel mixture will fall out of suspension and puddle. One must also think about the chamber design for full-burn of the mixture. Of course also think about matching the intake and carburetor ( fuel injection is better! ), the cam and exhaust.
Most engine builders look at the entire engine and it's application then match components to compliment each other. Just my thoughts on the subject...
Regards,
Gerry Dedonis
Kansas Racing Products Inc.
[ February 24, 2003: Message edited by: KSGerry ]</p>
  #26 (permalink)
Old 02-24-2003, 05:53 AM
engineczar's Avatar
Post
Gerry hit on one major point about the fast burn heads and that's the chamber design. Flowing big numbers doesn't always equate to big horse power. The flow numbers between a cast iron vortec and a fast burn are very similar. The abilty of the fast burn to produce better swirl is it's key to better HP numbers than the vortec. The word from GM is don't mess with the fast burns chambers, all you can do is mess them up.
I've also been working on two cast head setups. One uses s/r torquers and the other uses GM 492 castings. Common sense and flow numbers would lead you to believe that the s/r's would be a better head but so far the 492's continue to make more HP on the dyno.
The moral of the story is don't get hung up on big flow numbers, the sum of the entire combination is what's important.
BSE Racing Engines
  #27 (permalink)
Old 02-25-2003, 05:12 AM
ztoy's Avatar
speed freak
Post
So how do Dart Iron Eagle heads compare? They seem to do very well.
  #28 (permalink)
Old 02-25-2003, 06:28 PM
Post
ZTOY: Some dirt limited late model (class requiring steel block and heads) teams are getting 700-750 HP out of their motors using the iron eagle heads. These are probably the 230 angle plug head with a lot of angle milling and CNC port work however. What other 23 degree iron head have you heard of producing these kind of HP numbers.
  #29 (permalink)
Old 02-26-2003, 05:24 AM
ztoy's Avatar
speed freak
Post
cool, thats what I am running although I wish I was turning that king of hp with them! lol
  #30 (permalink)
Old 02-26-2003, 11:08 AM
F-1Rodder's Avatar
Post
Bill McCabe: I have been doing some research for an engine im building now and I will go with the steel vortec heads. couldn't justify the gains from using aluminum over the cast iron items. at $ 250.00 each ready to run this seems to be the best bargain going. What do others think.
I have built a 383 with the Vortec heads and could not agree with you more. They make huge power where you drive and beyond. For that extra 50 hp, you pay a large amount and use it very little in the aluminium head price range. Further, I have read that the aluminum fast burn is exactly the same head as the L31 Vortec except that it is aluminum.
