Iron powerglide converter? noise. - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-15-2012, 05:06 AM
south65ss's Avatar
Hi to all!
I just finished my 55 BA Powergide rebuild. I did it because it had several leaks but it ran very well. What I did found was the stator inside the converter had chewed something in the past so I changed the entire converter just in case for another I had laying around that looked excellent inside but had evidence of being working loose at least in one of the screw bosses. Now, when I start the engine theres nothing strange the first 5 or so seconds but after that it starts making a rhitmic noise that looks like one hit per rev. Its not a grinding noise but more like something-is-hitting-something kind of noise but not hitting very hard. The flexplate is straight and the trans works good the few meters I moved it. I think it must be the converter because theres not much more moving inside the trans when in park. Maybe when the front pump presurizes "something" it gets misaligned? Only thing I found odd inside the "new" converter was a bearing a little too worn out and that may be the cause of too much movement of the stator paralell to the axle.
What do you people think?
Old 12-18-2012, 08:59 AM
south65ss's Avatar
Update
Update.
I have the PG down and I have another converter. But I think I have something wrong here. If I take the input shaft (I mean the small axle that you see protruding fom the trans when you take out the converter) and make it spin with the trans not in park the driveshaft (wich is still connected) spins wit it. If I grab it with my hand I can stop it and continue spinning the other but should it happen that way?? How much drag should be between those two axles?
Thanks!
Iron Powerglide converter compatibility. south65ss Transmission - Rearend 0 11-27-2012 06:24 AM
cast iron powerglide rhoffler Transmission - Rearend 2 12-21-2010 09:27 PM
cast iron powerglide slingslingbinks Transmission - Rearend 2 05-24-2005 05:50 PM
Removing flywheel to converter bolts in a 1958 Chevy Impala 348 Cast Iron Powerglide 1958imp348 Transmission - Rearend 9 11-22-2004 03:18 PM
Cast iron powerglide slingslingbinks Transmission - Rearend 13 09-30-2004 10:18 PM
