-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   Iron stains in my driveway, remove? (http://www.hotrodders.com/forum/iron-stains-my-driveway-remove-223814.html)
68NovaSS 09-08-2012 07:11 PM
After fertilizing my yard, some granules on my driveway and garage floor when wetted, made bad iron rust stains, lots of them, and I can't clean them off. I've used my pressure washer, muriatic acid, The Works, Simple Green and two other "miracle" cleaners, nothing even touches them, I've scrubbed with a stiff brush until I was blue in the face...they're like BB sized stains, some have run down the driveway. The worst part is I just listed my home for sale, and had a showing today, they didn't like it at all!
Any ideas guys and gals?:confused:
302 Z28 09-08-2012 07:32 PM
Full strength Clorox, let it sit a while before washing it off.
Vince
nofearengineer 09-08-2012 08:23 PM
Just a WAG...you could try molasses.
LATECH 09-09-2012 06:22 AM
Boat guys use ospho to reduce or clean up stains in fiberglass that occur from the stainless pieces that rust. It has to soak for a bit. It is phosphoric acid. It might work...dunno.
CLR may have phosphouric acid in it, I dont know.It supposed to clean up rust stains too.Just a thought.
68NovaSS 09-09-2012 11:13 AM
Yeah Vince, I tried some bleach, didnt' let it sit too long, but didn't phase it. Molasses....sounds a little weird, maybe something we don't know about it...
I might try the boat cleaner, but I did find a review of some stuff called Super Iron Out from a gal in Killeen, TX, near me, had the same Scotts product stain hers, said CLR did nothing, so I'm off later to get some super stuff and give it a try. I have some stains in the garage as well, so maybe this isn't too far off topic for the HRB...
Thanks guys :thumbup:
nofearengineer 09-09-2012 06:11 PM
I have seen where old timers would soak car parts in molasses to remove rust. I'm not sure if it would do the same on concrete, but it's cheap and worth a try...if you don't mind ants. :D
rockable 09-09-2012 07:04 PM
Try Muriatic Acid. If that doesn't get it, you probably aren't going to get them off.
dinger 09-10-2012 12:31 AM
I had the same problem. Use toilet bowl cleaner, the kind that squirts upward in the toilet. The Works was good stuff, wife got it at the 99 cent store. Spray it on the spots, when it quits foaming, rinse with the hose. Might take 2-3 times, depending on how bad the stain is.
67Mustang Al. 09-10-2012 07:13 AM
Here is another one to try. When i sold my small yacht it had white nylon sails with rust spots in them from being wrapped up with wet steel fittings. The guy at the slip yard sold me a small jar of "OXALIC ACID". The rust spots came out to my amazement after leaving this stuff for about 5 minutes on the sail and then scrubbing with a hard brush.
Maybe be totally different on a drive but you never know.
Al.
302 Z28 09-10-2012 07:36 AM
It has been my experience after spreading fertilizer and getting rust spots on the sidewalk that they will fade and disappear after awhile from the sun.
Vince
302 Z28 09-10-2012 03:18 PM
Just a thought: On the suggestion of using Ospho. What happens when you use Ospho on rust? It turns black, so now instead of rust stains you have black stains.
Vince
LATECH 09-10-2012 04:39 PM
Vince
Good point Vince.:embarrass ;) Not sure. It doesnt leave a black stain on the boat,but that is fiberglass not concrete.
John long 09-11-2012 08:45 AM
Be careful that the Ospho does not eat the concrete. I know RustMort will and I believe they are ismilar products.
Gringo 09-11-2012 10:31 AM
Stains
Seems you have tried all my ideas. I would call fert. comp. and see what they say,
nofearengineer 09-11-2012 01:32 PM
Hey, I was just on a gardening website (no teasing :D) and someone had said they had great results using "The Works" bathroom cleaner on concrete rust stains.
http://www.ruralking.com/media/catal.../066070016.jpg
Only a couple bucks, so it's worth a try.
