Irs Coil Overs - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-28-2011, 09:42 AM
Irs Coil Overs
I have a 1934 Ford fodor with a four bar front suspension and a IRS corvette rear suspension. Can I install coil overs on these suspensions? If so, would it be a ride advantage? If so, what coil overs do you recommend?
Old 10-28-2011, 09:22 PM
evh1963's Avatar
WOLFE BOTTOM CUSTOMS
ifs coilover
www.trifive.com/forums/showthread.php?t=46973
Old 10-31-2011, 08:24 AM
I CLEARLY DO NOT UNDERSTAND THE USES AND ADVANTAGES OF COIL OVERS. I NEED A LITTLE DIRECTION HERE.
Old 11-03-2011, 08:26 AM
The advantage of a coil over is easy, wide selection of spring lengths / rates, clean install with minimal packaging. And yes, you can set up both front and rear suspension with a coil over.
Old 11-03-2011, 09:27 AM
Coil overs
Thanks for the info. Would you reccomend going in that direction and if so is there anything I sholuld look for or watchout for? This is going to be a driven hot rod and I want the best 'ride' I can get with it. Do you recommend air-ride?
Old 11-03-2011, 09:30 AM
I personally am a proponent for AirRide because I have driven daily drivers on air for the last 12 years however... its not for everybody. We also have a high end coilover and I have fitted several cars with coil overs and if it is done correctly, the car will handle great and ride excellent.
Old 01-10-2012, 09:04 PM
First off, what version of the Corvette suspension do you have? The C4 is very often fitted with coil overs fairly easy. The C3 can be converted. Van Steel has a set of trailing arms that are fitted for coil overs.
More IRS info at.
http://irsforum.boardhost.com/index.php
Ralphy1
Coil-overs easyrodder Suspension - Brakes - Steering 3 10-12-2011 03:49 PM
Coil overs Irelands child Suspension - Brakes - Steering 40 02-03-2011 09:54 PM
Coil Overs 123pugsy Suspension - Brakes - Steering 11 04-28-2010 03:47 AM
Coil-Overs mosstrooper Suspension - Brakes - Steering 1 05-01-2006 04:39 PM
coil overs. stickshift Suspension - Brakes - Steering 5 04-18-2005 10:50 AM
