Isis pros cons??? anybody - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2011, 11:11 PM
indydrt's Avatar
I bought it Master cell with 2 power cells , not installed yet in 33 roadster but got the remote option.
My friend had a kit.installed in a cobra.. Said battery went dead alot so install a battery cut off all he said, other wise was good .
Expensive though.
Old 01-21-2011, 03:36 AM
EOD Guy's Avatar
Not understanding what you are asking
Old 01-21-2011, 07:26 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
the only thing i know about them is they look cool, but to high tech for me, sorry i'm no help
Old 01-21-2011, 08:20 AM
Had this same discussion over at H.A.M.B. last week. I'm an aerospace engineer, we use multiplex systems like this all the time, and my feeling is that for automotive use this is the answer to the question no one asked. Overly complex, no real benefit in saved copper or connections, and impossible parts availability. Oh, and if you have a problem with a circuit in a conventional wiring system, you can jumper around it or do without it. If one of your ISIS modules goes south, you loose everything and you aren't going to be able to get parts at Pep Boys.
Isn't it interesting that all the car mags made a big splash when this first came out, and it hasn't been heard from since? More complex is NOT better.
Old 01-21-2011, 01:51 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
For those not familiar this is a multiplexing system with a Master cell (control head) and fused power cells that can located near the loads. The master cell is connected to the controls such as headlight sw, turn signal sw etc. The power cells are hard wired to the lights, horn etc. and require a power feed.
To techy for a hotrod. For me I'm a KISS kind of guy.
Simple is easy so why make hard. JMO
vicrod
Old 01-21-2011, 03:18 PM
EOD Guy's Avatar
Thxs Vic, I didn't know what that was.
Old 01-21-2011, 04:09 PM
& matts38chev
vicrod
see it here
Old 01-23-2011, 12:45 AM
indydrt's Avatar
vicrod
i might sell my ISIS 3 kit...not sure if i want to be stuck without a easy way out good point.. I might keep it simple..Thanks Vic
PROS & CONS ON PERTRONEX yragat Engine 16 12-12-2008 02:44 PM
pros and cons on 350 to 402 swap Robin Crowder Engine 4 02-14-2005 07:35 AM
'58 Anglia Pros &Cons? Dragon J General Rodding Tech 10 12-15-2003 07:07 AM
Pros and cons of LT1 in 70 GMC krue General Rodding Tech 4 08-07-2003 04:26 AM
327 vs 350 Pros and Cons Chevelle71 Engine 9 03-08-2003 10:49 AM
