-   Hotrodders' Lounge (http://www.hotrodders.com/forum/hotrodders-lounge/)
-   -   Isky 1012b (http://www.hotrodders.com/forum/isky-1012b-145127.html)
1fst7 09-14-2008 10:34 PM
Isky 1012b
I can't recall the specs on this old cam and I searched here and on the Isky site with no info. Just curious, I think it was 310 duration and .510 lift but I'm not sure. The wife and I got married and the hotrod Plymouth was our only car at the time. Fortunately I had a little common sense and took it easy with the car untill we were able to acquire another ride. I wasn't tired of wrenching on it but the new wife had other plans.
I didn't have any trouble with the Yenko's and Baldwin's but I did get embarassed by a ZL1 at the strip.
Times have changed from 40 years ago and I was just wondering how it would spec with the Comp Cams XE276HR I have in my RX7. Now the LSx cams are showing large durations and lift, times have certainly changed.
I know it's apples and oranges, Mopar and Chevy, big block and small block, but if any of the old Sox and Martin / Dick Landy fans could offer the specs, I would appreciate it. I've got the plate that came with the cam that you should stamp the specs on but I never did. I've probably got the card but I can't find it.
Thanks, Jim.
VJC 01-03-2016 05:04 PM
your cam was a 310 hi hyd from isky
specs
adv dur 310
dur @.050 244
lift .510
3000 to 7000 rpm range
had the same cam for my small block chevy great cam
Rich or Nolan from isky can grind a new one for your mopar
