Isky Cam Info? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2009, 08:37 AM
Isky Cam Info?
I am completing a 327 Chevy build that was started by someone else about 5 years ago. All of the machine work was done, new pistons, bearings, turned crank and new Isky Cam and lifters. I want to finish the build but need info on the Isky Cam. I have identified the Cam as a "201" Isky but need to know what the cam is set-up for. I need to know the recommended carb CFM, if it will work in an auto powerglide trans, what is the torque converter stall, etc. Does anyone have a suggestion where I can find such info?
Old 03-29-2009, 09:32 PM
carb for 327
you can ues a 650 cfm carb will be fine
Old 03-29-2009, 09:57 PM
automotive breath's Avatar
... I have identified the Cam as a "201" Isky...
You will need more information on the cam, the part number should be 6 digits, 201XXX
Old 03-29-2009, 09:59 PM
techinspector1's Avatar
Wiki Edits: 326
Spend a dime and call Isky in the morning....
http://www.iskycams.com/contactus.php
Old 03-29-2009, 10:59 PM
cool rockin daddy's Avatar
second techinspectors recommendation
will this cam work well? STLrocker Engine 9 03-29-2009 09:39 PM
Help Me Pick A Cam Canadian Charlie Engine 2 11-16-2005 02:11 PM
Stock cam info scheetz93 Engine 2 04-29-2005 12:54 PM
Isky cam Captnscotty Engine 1 09-23-2003 12:16 PM
another cam ouestion...ie...cam timing VETTE GUY Engine 0 06-28-2003 12:29 PM
