Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - isky cam selection
Old 05-16-2012, 02:07 PM
louis165 louis165 is offline
Originally Posted by ap72
If you want an isky cam call isky for a recomendation. Don't be affraid to ask questions and expect to spend more than 3 minutes on the phone.
That's what I was affraid of .. thanks ap.. I found this one seem to be close.. but I will call to make sure..:..... : 201027 GRIND NUMBER: z-27 ENGINE INFO: CHEVY SMALL BLOCK V8 265-283-302-305-307-327-350-400 CU.INCHES APPLICATION:
SPECIAL REMARKS: SOLID PRODUCT USE: STREET/STRIP
RPM RANGE: 2800-6800 Valve lift is calculated with zero lash and rocker ratio of 1.5
INTAKE TIMING DURATION: 282 deg. OPEN: 33 BEFORE TDC CLOSE: 69 AFTER BDC CAM LIFT: .338" VALVE LIFT: .507" VALVE LASH: .018 HOT .02 COLD
EXHAUST TIMING DURATION: 282 deg. OPEN: 69 BEFORE BDC CLOSE: 33 AFTER TDC CAM LIFT: .338" VALVE LIFT: .507" VALVE LASH: .018 HOT .02 COLD
LOBE CENTER: 108 deg. OVERLAP: 66 deg. CAM ADVANCE: 0 deg. THE ABOVE TIMING IS CHECKED AT .020 (OPEN) LIFTER RISE .020 (CLOSE)
The following timing is taken at .050" lifter rise and gives a more accurate determination of camshaft position. INTAKE DURATION: 247 deg. OPEN: 15.5 BEFORE TDC CLOSE: 51.5 AFTER BDC
EXHAUST DURATION: 247 deg. OPEN: 51.5 BEFORE BDC CLOSE: 15.5 AFTER TDC
RECOMMENDED ISKY CAM KIT PARTS AND SETUP INFORMATION
LIFTERS: 202-H LIFTER TYPE: SOLID SPRING: 205-D TYPE: SINGLE W/DAMPER DIA.: 1.250" RATE: 310 lbs per inch INSTALLED HEIGHT: 1.700" SEAT PRESSURE: 115 lbs OPEN PRESSURE: 268 lbs COIL BIND: 1.160" SPRING SHIMS: # 4 STEEL RETAINERS: 707-ST TITANIUM RETAINERS: PUSHRODS: 203-HG TYPE: NON-ADJ HEAT TREATED LENGTH: 7.781" DIA.: 5/16" ROCKER ARMS: 204 TYPE: ROLLER RATIO: 1.5 VALVE LOCKS: VL-32 VALVE LOCKS: VL-32 REV KIT:
home | what's new | tech info | news | catalog | apparel | about | contact
