Issues with 87 tbi 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2013, 09:47 PM
Its in a k5 blazer and the symptoms are as follows: Crank up is fine and you can feel real power and torque the first few miles. After you let off the gas and coast the service engine light comes on and she feels like she has about half the power. Pulling my little aluminum boat was pure embarrassing on the freeway. A year or so ago I made a genuine attempt to clear it up and I changed fuel pump, filter, rotor and cap, all plugs, and wires. Still doing it!
Old 03-16-2013, 06:12 AM
With the limited info I'm just going to throw a couple of things out there.
Have you checked you fuel pressure at start-up and when it starts running bad?
Have you replaced the catalytic convertor with a temporary test pipe?
ssmonty
Old 03-16-2013, 10:45 AM
Last journal entry: New ride3
SSMonty is right.
Sounds like a number of things it could be.
Have u check fuel pressure before and after the regulator? The regulator is built into the tbi unit in the back. Rebuild kits are cheap for them. This is a common side effect of the spring being bad. I would start there.
Problem is probably in the TBI unit, maybe injectors..
Or
Intake coolant temp sensor. Especially since it seems to doit once its warmed up. EGR could be clogged. Bad MAP. Bad cats, Maybe? It could be any number of things.
Old 03-16-2013, 12:18 PM
Here's a thought. Rather than guessing and throwing money at the engine, why not figure out what codes are causing the CEL to come on? That might lead you to the real problem.
The Following User Says Thank You to joe_padavano For This Useful Post:
LATECH (03-16-2013)
350 TBI stalling issues smallblockbigproblem Engine 8 07-11-2011 03:14 PM
TBI 350 Idle issues...again... shane.,herold Engine 7 05-24-2011 06:27 PM
TBI issues DoubleVision Engine 4 05-22-2011 07:05 AM
1987 v10 surburban 350 tbi/electricial issues? risquecj7jeep Engine 2 10-21-2010 09:55 PM
tbi 4.3 issues, fast68 Engine 5 09-01-2009 05:57 PM
