It's alive...finally - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2005, 06:06 PM
AngliaBob's Avatar
It just takes time and money
Last journal entry: Specifications
Just finished the break in on the newly rebuilt motor. Everything went fine, no funky noises, but after 15 minutes the temp was at 210 (with both fans on and 180 thermostat). I shut it down and let it cool, and then ran it for another 10 minutes. Everything seems OK. I wasn't happy with the oil pressure it started at 50lbs and dropped after 15 minutes to 35 @ 2000rpm (temp 210), so I pulled the pan and shimmed the pump. Now it's running 65lbs @ 2000 rpm @180, I feel much better. Next project is the trans, my pressure gauge should be arriving Monday via UPS. I tried to post some new pix in the Photo Album yesterday, but the bugs aren't worked out yet. The motor specs are in the Photo Album, if anyone is interested.
AngliaBob
Old 02-18-2005, 07:15 PM
camaroman7d's Avatar
YIKES!!! Why would you want more oil pressure than you already had? 35psi at 2000RPM was just fine. You only "need" 10psi per 1000RPM (10psi @ 1000, 20@ 2000, 30@ 3000, etc...).
The extra oil pressure is not gaining anything for you.
Congrats on the new engine.
Royce
Old 02-18-2005, 07:38 PM
lluciano77's Avatar
You may have had air in the cooling system. Running it the first time may have worked it out.
I prefer higher oil pressure. That way if you lag on the oil changes etc, it still keeps the pressure up.
Old 02-18-2005, 08:02 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Pressure means nothing. It's all about the flow.
Old 02-18-2005, 08:27 PM
lluciano77's Avatar
Pressure means everything. Pressure changes the boiling point of liquids.
Pressure means nothing? Are you kidding?
Old 02-19-2005, 01:46 AM
"Pressure means everything. Pressure changes the boiling point of liquids.
Pressure means nothing? Are you kidding"
Please tell me you are kidding? Pressure does not mean "everything" once you have the necessary amount of pressure (which has been proven to be ~10psi per 1000RPM) for the cushion, adding more pressure doesn't help. Having a little more than 10psi per 1000RPM's is not bad but, there is no need to have 65psi at 2000RPM, that is only going to help wear out the distributor gear faster.
Now your point about pressure increasing a liquids boiling point. My goodness!! While this is true in a radiator (closed pressurized system) that does not hold water (excuse the pun) when it comes to oil pressure. Here is a simple example for you a given engine has 10psi of oil pressure @ 1000RPM (using 0-5wt oil) now you change the oil in this exact same engine with 50wt and the oil pressure @ 1000RPM is now 40psi, how did that "change the boiling point" of the oil. It didn't the thicker oil increased the pressure, just as cold oil does and tight bearing clearances. It is quite the opposite, the higher the oil pressure the hotter the oil tends to get. Also the oiling system is not "under" pressure the pressure is created by the oil being pumped through passages, the pressure is a result of the oil "backing up". The oil system is not a closed system, excess oil just gets flung off of the crank shaft. When was the last time you saw oil boil? If you did at what temperature was that?
Higher pressures do not allow extended oil change intervals. You can have 60psi of pressure with water in the oil system, that doesn't mean it's ok to use water in the place of oil. Once the oil is dirty and or broken down it no longer lubricates like it is designed to, just because you still have good oil pressure doesn't mean the oil is still doing it's job. Do you think shoving all the dirt and debris through the passages harder will eliminate damage?
Please tell me you were kidding, even if you really meant what you said.
Royce
Its Alive....ALIVE!!! Hot Rod Bod General Rodding Tech 7 07-30-2004 10:08 AM
I finally got the Stallion home CrashFarmer2 Hotrodders' Lounge 2 07-16-2004 06:19 PM
Finally Got A Car!! crazygutgut Hotrodders' Lounge 16 04-19-2004 10:39 PM
finally a good day akm Hotrodders' Lounge 3 04-05-2004 01:10 AM
Finally some good luck. 78 monte Hotrodders' Lounge 14 08-28-2003 05:35 AM
