-   -   Its an engine (http://www.hotrodders.com/forum/its-engine-231981.html)
bygddy 04-18-2013 08:18 PM
Its an engine
Hope this doesn't get moved to obscurity....it is after all, an engine ;)
Motor was so clean when the old heads came off, I could actually clearly read the pn# on the top lol.....speedpro flat tops, 30 over. New heads installed tonight with arp bolts, intake is just sitting for hood clearence check but had to snap a pic.....so happy! Will hopefully have running saterday......then goes to have the hood painted matte black,and the wheels powder coated black.....thats all for now, I'm sure I will have Carb and timing questions soon for here.
http://i46.tinypic.com/vs0668.jpg
techinspector1 04-18-2013 08:37 PM
OK, might just as well get this stuff handled now....
http://www.crankshaftcoalition.com/w...op_dead_center
http://www.crankshaftcoalition.com/w...ips_and_tricks
http://www.crankshaftcoalition.com/w...stment_SBC/BBC
http://www.crankshaftcoalition.com/w...g_a_carburetor
http://www.crankshaftcoalition.com/w...pe_air_cleaner
http://www.crankshaftcoalition.com/w...g_vacuum_leaks
http://www.crankshaftcoalition.com/w...EI_distributor
http://www.crankshaftcoalition.com/w...rebuilt_engine
http://www.crankshaftcoalition.com/w...al_vacuum_leak
Custom10 04-18-2013 09:15 PM
Tech are you surfing from your lazy boy again?. ;)
Dont forget link to fuel pressure check out,,,or is it in there somewhere?
TJ
bygddy 04-18-2013 09:24 PM
I just burst out laughing...
TDC was verified with a stop before I pulled the heads, balancer is accurate
Cam was already installed and i left it alone and did stay with 1.5 rockers as per your recommendation
Valve adjustment I haven't yet had a problem with on past builds, and do use the "jiggle up and down" method as opposed to spinning them
Carb, well in theory it should have a VC instead of the 750dp but I always prefer mechanical and have had success making them work for me.
Drop base I have, and the hood looks like it closes with a 1/2 inch to spare even with a 1" spacer
Vaccum leaks.....don't know yet but lets hope not
HEI has been modified by previous builder, has a 15 curve and is all in by 2500
And i left the short block as is, stock crank, "pink" rods, speedpro hypers, zero decked, lots of expensive machine work and arp throughout. With receipts to verify and approx 8000k since it was done.
So will hope this goes smoothly the rest of the way. Still have to reinstall exhaust, set lash, intake, dist, plugs, wires, fluids, pushrods should be here tommorow, so aiming to fire it saterday.
Custom10 04-18-2013 09:48 PM
Great, it is about to roar,,,good luck
1Gary 04-18-2013 10:23 PM
With everything you have been through with this,can't think of anyone more deserving of clear sailing from this point out.
spinn 04-18-2013 10:33 PM
She is a beauty. Good luck.
8k Yikes!
bygddy 04-18-2013 10:40 PM
8k Yikes!
Lmao.....I'm Canadian, 8000 kilometers since it was built.....
bygddy 04-18-2013 10:42 PM
Thanks for the kind words gentlemen.....I hope it makes a fun little street motor.
S10 Racer 04-18-2013 11:00 PM
It does look good. Do yourself a favor and get rid of that Fram oil filter. Congrats!!!:thumbup:
techinspector1 04-18-2013 11:32 PM
Was it that obvious?:sweat:
TimoFinn 04-19-2013 01:51 AM
What`s wrong in a Fram filter?
gearheadslife 04-19-2013 02:00 AM
that fact that they pass it off as a filter..
1Gary 04-19-2013 02:58 AM
wix!!!! Please
bygddy 04-19-2013 03:18 AM
Had read that here before, and yep, will be doing so tonight for sure....that was the PO that thought it was a good idea to use fram
Thanks!
