Its an engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2013, 09:18 PM
Proud LOSER
Its an engine
Hope this doesn't get moved to obscurity....it is after all, an engine
Motor was so clean when the old heads came off, I could actually clearly read the pn# on the top lol.....speedpro flat tops, 30 over. New heads installed tonight with arp bolts, intake is just sitting for hood clearence check but had to snap a pic.....so happy! Will hopefully have running saterday......then goes to have the hood painted matte black,and the wheels powder coated black.....thats all for now, I'm sure I will have Carb and timing questions soon for here.
Old 04-18-2013, 10:15 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
Tech are you surfing from your lazy boy again?.
Dont forget link to fuel pressure check out,,,or is it in there somewhere?
TJ
Old 04-18-2013, 10:24 PM
Proud LOSER
I just burst out laughing...
TDC was verified with a stop before I pulled the heads, balancer is accurate
Cam was already installed and i left it alone and did stay with 1.5 rockers as per your recommendation
Valve adjustment I haven't yet had a problem with on past builds, and do use the "jiggle up and down" method as opposed to spinning them
Carb, well in theory it should have a VC instead of the 750dp but I always prefer mechanical and have had success making them work for me.
Drop base I have, and the hood looks like it closes with a 1/2 inch to spare even with a 1" spacer
Vaccum leaks.....don't know yet but lets hope not
HEI has been modified by previous builder, has a 15 curve and is all in by 2500
And i left the short block as is, stock crank, "pink" rods, speedpro hypers, zero decked, lots of expensive machine work and arp throughout. With receipts to verify and approx 8000k since it was done.
So will hope this goes smoothly the rest of the way. Still have to reinstall exhaust, set lash, intake, dist, plugs, wires, fluids, pushrods should be here tommorow, so aiming to fire it saterday.
Old 04-18-2013, 10:48 PM
Custom10's Avatar
Great, it is about to roar,,,good luck
Old 04-18-2013, 11:23 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
With everything you have been through with this,can't think of anyone more deserving of clear sailing from this point out.
Old 04-18-2013, 11:33 PM
spinn's Avatar
She is a beauty. Good luck.
8k Yikes!
Old 04-18-2013, 11:40 PM
Proud LOSER
8k Yikes!
Lmao.....I'm Canadian, 8000 kilometers since it was built.....
Old 04-18-2013, 11:42 PM
Proud LOSER
Thanks for the kind words gentlemen.....I hope it makes a fun little street motor.
Old 04-19-2013, 12:00 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
It does look good. Do yourself a favor and get rid of that Fram oil filter. Congrats!!!
Old 04-19-2013, 12:32 AM
techinspector1's Avatar
Wiki Edits: 326
Was it that obvious?
Old 04-19-2013, 02:51 AM
What`s wrong in a Fram filter?
Old 04-19-2013, 03:00 AM
Banned
that fact that they pass it off as a filter..
Old 04-19-2013, 03:58 AM
1Gary's Avatar
wix!!!! Please
Old 04-19-2013, 04:18 AM
Proud LOSER
Had read that here before, and yep, will be doing so tonight for sure....that was the PO that thought it was a good idea to use fram
Thanks!
350 Crate Engine: Loud humming sound after engine warms up sofa1515 Engine 2 01-11-2010 07:48 PM
I need engine mount bracket ideas 1930 chevy with 302 boss engine. Riley Engine 3 07-25-2008 08:29 AM
Ford 302 engine to engine stand bolt size? Lee in Texas Engine 4 03-24-2008 11:30 AM
95 ford F-150 engine swap, Same Transmission fit new engine? F-150 Transmission - Rearend 5 10-07-2007 01:11 PM
say you have a THOUSAND horsepower engine..... (technical engine question inside) lowROLLERchevy Engine 14 02-24-2007 09:26 AM
