It's getting hot!! Why oh Why? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-30-2002, 10:56 PM
New Member
Post
Haha..That was funny.
  #17 (permalink)
Old 12-30-2002, 11:01 PM
Question
If all the above fails, this could get nasty.
Pulling the thermostat on a flathead V8 with two water pumps would cause dramatic overheating as there was too much pump power. The coolant WAS rushed through the radiator so quickly heat was retained instead of transferred. However Henry has been gone lo these many years and the mavens signing off on vehicle design will no more overdo anything if they can shave a penny.
I have done the upside down thing myself. I have also so consistently been sold the wrong parts by the major discount retailers that the box is opened on the spot and pieces compared before the counter trainee gets away. Just because the part is new does not make it right. It's possible the thermostat is the wrong one and it pinches when you tighten the bolts, not allowing the valve to function.
When you open the hood as the truck overheats, is the fan clutch operating, IE: is the fan turning at engine speed?
Can you see coolant swirling by through the radiator cap opening?
Are BOTH hoses hot at the entrance to the heater box?
If only one is hot, squeeze the cold one with a clamp and gently release that hose at the heater nipple. This should allow coolant to be forced through even a partially clogged heater core. BE VERY CAREFUL. If you are overheating, this stuff will take your skin off in a heartbeat. After you get coolant flow, re-attach the hose. It should then pass coolant along it's length to the engine connection.
As an aside, if you have no, or sluggish flow through the heater core, as long as you are in the vicinity with a hose unhooked, grab the garden hose and do a little backflushing. Use a little common sense as the heater core is designed for twenty PSI and the garden variety garden hose can push out sixty on an ordinary day.
Do you have a brown residue trail at the bottom of the tail-pipe?
Do you hear a definite thud sound at the tailpipe, sort of a dead second instead of the spit of regular exhaust?
Does the truck spit through the carburetor?
If either of the above two occur, use an insulated device to remove spark plug wires one at a time to isolate the offending cylinder(s).
Run a visual inspection of the spark plug(s) from the suspect cylinder(s) then a compression test.
If you hold a piece of paper across the tailpipe and let the truck run, does it become wet?
Did any of this help?
  #18 (permalink)
Old 12-31-2002, 12:05 AM
New Member
Post
My Goodness. That was the best reponse ever. thanks a lot!! With that I believe I can trace it. A lot to work on, I'll let you all know what I find.
  #19 (permalink)
Old 12-31-2002, 12:09 AM
New Member
Post
Oh, by the way. I have not tried a compression test, the tail pipe inspection or gone to the heater core. I would hope that it was anything other than the heater core or the head gasket. Trying the heater core test first then gasket.
  #20 (permalink)
Old 12-31-2002, 06:21 AM
Post
Something else to check that won't take much time is to pull the radiator. Hold it up so you can look thru it. I have had simular problems to yours and found the radiator cooling fins so full of crap that air couldn't pass thru it.Wash and blow it out ,you won't believe how much crud will be trapped. I did this with my 86 f-150 and cured a serious overheating problem.
  #21 (permalink)
Old 01-01-2003, 09:46 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
Post
if it still isn't working right, replace the sending unit. after replacing everything in my cooling system except the sending unit, it still "ran" hot. replaced the $4.86 pos and now have a complete brand new cooling system. btw, If your sending unit is disconnected, how do you know your temp?
  #22 (permalink)
Old 01-02-2003, 01:05 AM
Post
the thermostat could still possibly open when it is upside down but just at different times than normal (obviously). i had mine on upside down <img src="graemlins/spank.gif" border="0" alt="[spank]" /> and it would register on my actual temp gauge really funky. it would heat up to about 230 and then drop down to 180 really quick. so im just saying that it could be upside down but it still might open.
