It's getting hot!! Why oh Why? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2002, 08:48 AM
New Member
Red face It's getting hot!! Why oh Why?
Here's a confusing one for you guys. 1987 Ford F-150. New Fan Clutch, Thermostat, Upper and lower radiator hoses and water pump. Thermostat checks good. Water pump checks good. Fan cluth and fan, good. Hoses, good. Water circulating. No oil in coolant, no coolant in oil. Still over heating, but not in idle, only on the road. Over heats over a length of 1 block! What's the deal, I am at the end of my rope. <img src="graemlins/pain.gif" border="0" alt="[pain]" />
Old 12-30-2002, 09:03 AM
slider in wa's Avatar
Slider in Wa.
Post
Flush out raditor and block? Check timing?
Slider in Wa.
Old 12-30-2002, 09:22 AM
New Member
Wink
Flushed but have not checked timing.
Old 12-30-2002, 09:26 AM
Kevin45's Avatar
Just one of the guys
Post
Is it actually overheating or are you going by the gage or idiot light. If the gage pegs or the light comkes on it might possibly be a sending unit. Does it seem to cool when you turn the heater on or stay the same? Would it be possible that you have an airlock in the system. Just a few suggestions.
kevin
Old 12-30-2002, 09:27 AM
awsum34's Avatar
Post
Is the fan a clutch fan? It might of went bad
Old 12-30-2002, 09:48 AM
New Member
Unhappy
The idiot light is disengaged, or should I say that I have yet to replace the sending unit. I did not think that the sending unit could cause the problem, so I have focused on other areas first. It may be relavent to say that the truck has California emissins and required the replacement of the old clutch, which would not attach to the mounts on the new water pump, with a clutch that would. But, the problem existed before these units were ever replaced. I also replaced the rear feeze plug by dropping the transmission. There is no further sign of leakage. Wish I hadn't, because I have to reset the transmission T/V line. You can probably see how this is getting to me at this point. <img src="graemlins/crash.gif" border="0" alt="[crash]" />
Old 12-30-2002, 11:46 AM
New Member
Post
I know your problem........................................... ............ its a FORD LOL...... go chevy u cant lose...
Found
On
Road
Dead
Fix
Or
Repair
Daily
Old 12-30-2002, 11:55 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
How hot is 'hot'.
Old 12-30-2002, 12:10 PM
awsum34's Avatar
Post
When you say running hot. Is it boiling over? Or just running hot.
Also you said your running hot going down the road. You didn't take the air damn off did you? without the air damn not to much air is forced through the radiator.
Old 12-30-2002, 02:36 PM
dmorris1200's Avatar
doesn't play well with others
Post
Is your shroud still there? Air in the system could cause this effect. Was she burped properly to get all of the air out of the system. Is your overflow tank hooked up and working correctly?
Old 12-30-2002, 08:20 PM
New Member
Post
The shroud is still in tact. As far as burping the coolant system, I am sure that I didn't do this, since I have never had to. Could you lend me advice on this procedure?
Old 12-30-2002, 08:31 PM
New Member
Post
i have simular problem with my 92f250 so i took out the termostate and it dont do it running down the road now it only does it under stess i.e light loads as my s 10 that has spent more time on a trailer than the road
Old 12-30-2002, 08:49 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
Burping the radiator is easy if you have a bleeder in the cooling system. But since you probably don't, take the radiator cap off and start it up. Watch for the coolant to flow (t.stat open) and slowly top it off with coolant rev it a few times to stir things up a little (make sure the heater temp control is on full hot). If needed, you can raise the front of the truck up to ensure that the air finds the highest point and escapes through the filler neck. How is the condition of the radiator cap? I have never had problems with the truck model you have as far as air in the cooling system. Feel the cores of the radiator all over (warmed up engine off), for any areas that aren't as warm as the others. This would indicate clogged cores. If it is a single core radiator, I would definately suspect core blockage.
Old 12-30-2002, 08:58 PM
New Member
Post
Thanks. I will try the burp and also check for head gasket leaking. I thought that removing the thermostat would lend to overheating, since the coolant doesn't spend enough time out of the block to cool. Maybe I was wrong about that one, huh. Thanks guys, I hope that I can give advice to some of you one day.
Old 12-30-2002, 09:21 PM
Post
my uncle couldnt figure out why his was over heat ing and he checked everything and it turned out that the thermostat was on backwards. so it never opened up
