Its Official Using OmNi Paint - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2004, 11:08 PM
Well im Using omno white paint plan on getting 1 gallon of sprayable brite white the car is a 86 iroc camaro its fleet white with lots of primer on it right now its ready to be sprayed for this omni i was quoted at 165$ for all the paint reducers thinners and a gallon of clear is that a good price for it? i asked around about Nason but no one had any of it and reading im guessing omni is just as good? or close to it and well for under 200$ for all my paint and clear sounds like a hella deal
Old 06-22-2004, 05:14 AM
BarryK's Avatar
Sounds like the plan, to me!
Old 06-22-2004, 06:22 AM
Wiki Edits: 49
I'm using Omni Acrylic Urethane on my truck and for an inexpensive paint it works very well. The only drawback I have found so far is that it doesn't contain the same amount of pigment as more expensive paints so if you'r covering a dark color with a lighter one you will probably have to add a couple coats to get the same coverage. Other than that it seems to spray very well.
Here's a pic of the cab right after painting. Color is 1969 Dodge Hemi Orange.
Centerline
Old 06-22-2004, 08:35 AM
i was worried it wasnt a good paint but sounds like Barrys cool with omni line so im leavn to buy it rite now finaly after months of anticipation!!!!!!!!!!!!!!
Old 06-22-2004, 09:28 PM
sportbikeluvr's Avatar
Centerline looks AWESOME guy!
Aces: Ive heard nothing but raves about the Omni line and like what center said its biggest downfall is the amount 'hiding' from everythng Ive read about it.
The ONLY other option Ive that may be worth it if ur budget allows it is getting the higher end clear. As is ur saving some $$$ on the Omni base, Im not sure what the difference between the Omni clear and PPG clear is but it might be worth looking into.
Gdluck!
Old 06-22-2004, 10:02 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
that's cheaper than i paid for mine.
i thought the omni clear was great. the only problem i had with it was my inexperience.
