It's a snap wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2004, 08:35 PM
302 Z28's Avatar
It's a snap wiring
Anyone install this harness? What are your opinions of it. I am really interested in the micro fuse panel.
Thanks
Vince
Old 06-18-2004, 08:41 AM
302 Z28's Avatar
Called the folks at It's A Snap Wiring and talked with Rick. Wow, what a wealth of information I received free of charge. I had been considering a competitors 14 circuit micro fuse panel for my 34. It sells in Jegs catalog for upwards of $300.
I then ran across an advert for the It's A Snap ZZ-20 20 circuit harness for $135. Rick told me they use a higher quality GXL wire, the very same wire GM uses for underhood applications. The other firm uses general purpose TXL automotive wire. Their wire is GM color coded, labeled and numbered every foot of it's length. The alternator wire is 8ga vs 10 ga for the other firms harness. I ordered one on the spot.
Vince
Old 06-18-2004, 09:18 AM
Tim240Z's Avatar
http://www.itsasnapwireandcable.com/
Looks nice...
Old 06-18-2004, 09:45 AM
EBlack36's Avatar
Rebuilt Excitment
The same people also own TPI Tech and I am running one of the harness on the TPI in the 36. easy to use.
Old 06-18-2004, 06:19 PM
Wiki Edits: 49
Purchased one of their kits for the truck. Haven't gotten around to installing it yet but will get started in a couple weeks. I saw the stuff first hand at the NSRA Nats a couple years ago and was very impressed. Nothing proprietary like some of the other guys and the wire he uses is top quality. The whole kit is simple and straight forward.
Centerline
Old 06-18-2004, 07:24 PM
302 Z28's Avatar
I especially like the price. Painless is good quality but IMO is waaaay over priced, Case in point: I need a couple of Maxi fuses and holders. Painless gets $30 each from Summit. I found the exact same thing made by Littlefuse at an electrical supply house on the net for $19.99 each with fuse. Their switches like headlamp, dimmer and such are also marked up quite a bit.
Vince
Old 06-18-2004, 09:34 PM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
Wow. NICE kit! I thought EZ-Wire was great for $165, but this is the way I would go if I was doing it today!
See my installation Here
Alan
54 Chevy Pickup
