Now I seem to get low oil pumping out the pushrod,when they are tight, when loosen up the rockers and they are chattering oil pumps everywhere out of the pushrod. |
I like to use wd40 on them, but that's a good idea it oils them up and they come off easy.
F-Bird is the reason I love sites like this.
F-Bird shows that there is always someone with the right answer if you can find him. Getting it here, for free, is a great thing.
By the way, there are several very good ooil deflector tins available through most auto parts stores to deflect all the oil from splashing everywhere during valve lash adjustment. Once you buy a set you will wonder why you didn't think of it they are so simple. I highly recommend them for anyone doing "open valvve cover surgery" on their valves. Just a thought... |
dwb, I had no problems with oil going everywhere, that's what I was writing about, it's real odd.
I also agree F-Bird does know alot and makes some sense of it all.
What's really nice is how helpful everyone is. Tossing up a lot of ideas. |
Ok I have the recurve kit and a new advance can. I grabbed new Gaskets for the intake manifold, I was curious how do I install the block off in there, on what side of the gasket does it go?
I waiting on the new Pushrod cover(valley pan) gasket, while I am there I might as well open it up and look in see if there are any issues there plus it's starting to leak. |
There's a possibility you're oiling holes between the pushrod and rocker aren't lining up, pushrod wrong length, guideplate issue if used or incorrect, etc., that could be not allowing sufficient oil to the upper end. I've seen burrs in pushrod pockets blocking oil, you can clean them up gently with a drill.
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
Duke |
Lifters only I did the 2000 rpm's at 15 mins. and then changed the oil. I will know the condition of the cam and lifters tomorrow as the top of the engine is coming off for inspection. |
I looked at my distrib. specs and it seems to do what F-Bird says it should do these are the specs:
If the rebuilder set it to specs are: Centr. adv. starts at 800rpm's Interm. points deg. 23-27@1900 and 32-36@4600 Max. deg. 32-36@6000 Vacuum advance starts at 6-8"hg max.deg. 20@13-15" I'm gonna change the weights and the advance unit anyway, always best to have new working units. I also will pull the intake and the pushrod cover and do an inspection of cam and lifters, check things out plus my cover has a little leak, and gonna blank off the heat riser, no hole, not needed, don't run it in the winter and the engine gets hot enough. |
I disassembled the distributor this morning and found that the bushing I'm supposed to replace isn't there, a plastic one, on the limiter,
I'd be having it spun up on a distributor graph to make sure of what you've got. Those figures you reckoned on the dissy advance curve points, are you taking the static setting into account or is that just mechanical advance. That seems a lot, even without the bush missing. Doesn't give you much room to set your initial advance up much? Duke |
those settings are factory Specs off the build sheets for the 67 Firebird.
| Valve Lash | jor | Engine | 17 | 09-16-2012 12:52 AM |
| I'm told to check the Ballast Resister... | sscardino | Engine | 3 | 12-31-2011 02:37 PM |
| Valve lash | badknuckles | Hotrodding Basics | 16 | 05-31-2011 03:54 PM |
| valve lash | eclipse90108 | Engine | 0 | 07-26-2009 07:16 PM |
| valve lash??? | chevyelc81 | Engine | 5 | 03-29-2009 07:25 PM |
