I've been told to check my Valve Lash? - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 09-07-2012, 12:52 PM
your talking pulling the whole engine out, it's still in the car.
  #47 (permalink)
Old 09-07-2012, 03:52 PM
thinwhiteduke's Avatar
Living In The Past
Wiped lobes, sorry to hear that. I thought once a cam survived the break-in and ya kept the zinc up, it was all good. I got about 500miles on mine now, I hope it don't go south. Like I said before, I'm no expert but I wonder HOW bad the bearings would be. Surely the filter system account for something.
Good luc.
Duke
The Following User Says Thank You to thinwhiteduke For This Useful Post:
raguza123 (09-07-2012)
  #48 (permalink)
Old 09-07-2012, 04:08 PM
I'm a fanatic about oil and changing it, I had about 18000 on this cam, I think it was never right from the start.
I hope my filter stopped all the metal.
  #49 (permalink)
Old 09-07-2012, 05:19 PM
Living In The Past
Don't take my word for it that everything's gonna be alright, I was just wondering if everybody that has a cam go bad, completely pulls their engine down.
Maybe some pro's with more experience could chime in..
Duke
  #50 (permalink)
Old 09-07-2012, 06:00 PM
Ya know I remember when I broke it in, it got real hot during it. That is the engine break in, I made the mistake 2 yrs back of hearing a ticking sound so I decided to replace the lifters only, that was the final nail in the coffin for the cam. Lesson here is replace both together.
  #51 (permalink)
Old 09-07-2012, 07:31 PM
WDCreech's Avatar
Grumpy Old Goat Herder
You can put new lifters on a used cam, but you need to go through the break in process all over again, using an oil with high zddp content.
Bill
  #52 (permalink)
Old 09-07-2012, 07:56 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I put a vac gauge on it, it idles at 12" steady, when I remove my bake booster and the advance and trans modulator, it goes to 13" steady.
When I accelerate it has no lag or bog, the needle drops to 2" then up to 18", if I hold it at 1500rpm's she go back to 12 or 13" and bounce a little between the two of them.
It's has about 18000 miles on it since it's total overhaul, I just realized I'm running a modified from stock specs at stock specs. since it was rebuilt.
It starts good and revs good, but I have a sputter at idle out the exhaust.
At least now there is a cause. Although I do have to say that while a worn cam lobe can account for the engine not running right (tapping/noisy valve train, valve(s) that will not hold an adjustment, popping through the carb or exhaust, etc.), in your case the diagnosis wasn't cut and dry at all. Here is a page w/info that can help avoid another cam failure.
Good luck.
The Following User Says Thank You to cobalt327 For This Useful Post:
  #53 (permalink)
Old 09-07-2012, 08:23 PM
I did not go through the break in process like that, I will now, as it cost me a lot of time and the cost of a Camshaft and headache and it was the culprit the whole time. So is there a good break in oil or just an additive like comp cams recommends.
There's some interesting stuff there about cam's and what will happen.
  #54 (permalink)
Old 09-09-2012, 04:33 PM
I found 5 lobes worn, 2 are starting to get worn and 1 is iffy. I removed all the compoenents and I ordered a Cam/Lifters/timing set and should have it tomorrow.
I also went through her, I drained the oil and drained it through a paint strainer and found very little dirt. I then opened up the filter and inspected the element and it was farely clean, it was from last year. I then left the drain plug out and dumped in the block and heads mineral oil, and then jacked up the rear to be sure it all drained out and strained that and it was clear.
Then I checked the pushrods, rolled them on a piece of glass and found one bent, some with wear at were they come thru the head.
That's about it, now on to the what do I do next?
  #55 (permalink)
Old 09-10-2012, 09:23 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Ideally, you would take the engine back down to throughly clean it of any traces of the worn out cam and lifters.
This means pulling the engine and will require you to reseal it w/new gaskets and seals as well as replace the bearings if they are damaged. If the cam bearings aren't removed, the oil passage/groove behind them has to be completely flushed out. Same thing for the passage under the rear main bearing in the block (more on that HERE), the oil pan baffle, and all the oil galleys including those alongside the cam bore, the crank oil passages. Basically everything exposed to oil needs cleaning. The less cleaning, the more chance there will be increased bearing and journal wear and a shorter engine life.
raguza123 (09-10-2012)
  #56 (permalink)
Old 09-10-2012, 11:28 AM
So what you are saying is I will have to pull this engine in the very very near future to replace everything bearings and such.
It doesn't matter how much I clean her now. It will fail soon again?
Unless I do it now.
  #57 (permalink)
Old 09-10-2012, 02:01 PM
Yeah! that is what I heard. The metal from the cam and lifters has to be somewhere. As you said you didn't find much in the oil filter or in the pan when you flushed it.
The Following User Says Thank You to cdminter59 For This Useful Post:
  #58 (permalink)
Old 09-10-2012, 08:07 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Unless I do it now.
Thorough cleaning is definitely the preferred method. Unless the vehicle is needed for work or something important that makes getting it back on the road fast a priority, I will still have to say to pull, clean and reassemble. If that's not possible, just do the best you can- pull the pan and spray it down w/a strong 409-type spray cleaner and rinse w/plenty of (hot if possible) water. Carb spray can also be used to get into the crevases. The oil galleys that run alongside the cam tunnel are hard to clean in the car, as is the grooves behind the cam bearings, but w/persistance you can get most of it.
Unfortunately, no one can say w/certainty how long the engine will last if it's not totally disassembled for cleaning- but it probably won't have the same life expectancy as an engine that was assembled 100% clean. That said, it might go 100K miles w/o a tear down- who knows...
raguza123 (09-11-2012)
  #59 (permalink)
Old 09-11-2012, 05:11 AM
I have never been happy with it anyway, it's been a headache since she was rebuilt. Maybe this was the issue from the start, I don't expect it to last 100K, the engine needs to pulled out for a cleaning just on the outside alone, and when I get around too it it'll be torn down then. I realize the shop has done something wrong and it needs to be looked into and I may decide to scrap it and go for a little bigger engine.
  #60 (permalink)
Old 09-12-2012, 12:20 AM
Looks like I got in on the tail end of this one... Hard to address all the issues covered by the thread.
Can't seems to make things add up. When you get it back together, neither the booster or vacuum modulator should cause any change in the reading. A wiped lobe on the exhaust would definitely cause "sputtering" exhaust on accel, but would also cause a jumping vacuum gauge, not steady. Should also have been "fluttering" thought the intake. Hard to tell if 12-13" was normal, not knowing what the cam spec is for duration. For stock, you should have 18-20. If it was gutless or doggy from day one, then I would have suspected the cam timing was off, be it incorrect keyway location, or a worn chain/gearset. (Crappy products available today can go south in a hurry.)
If you're using Fram oil filters... don't. They rate the worst in particulate passage and bypass circulation. Hastings is up at the top, as well as the Gold series Napa with close to a 10 micron absolute filtration. If you change your oil as much as you say and are using good filters, you shouldn't incurr any problems by not tearing it completely down. Not saying that tearing it down is not the way to go, just saying that many can't afford it, and I've seen a LOT of severely dirty engines go a LOT many more miles after having been flushed and oil changed at short intervals for the next few hundred miles. You'll never go wrong running Royal Purple, either.
Didn't see any compression numbers, which would be highly relevant to where your iginiton timing should be, also correlating to the lift/duration specs of the cam. The best you could do is leave it at the stock 8 degree setting, especially when running in the area of 9.5:1 or higher. The high numbers provided work great for high revving racers, but don't produce the drivablilty you're probably looking for. Same with the cam. The best you might want to do is use the numbers of a Ram Air III 400. Nice, smooth, stable idle with really good light foot drivability and torque, turns on like a rocket above 3500 rpm. Don't run your base timing any higher than 8 degrees.
1970 was the last year for advanced cam timing gear keyways. 1971 retarded the cam timing by cutting the keyway in a different location. Back in the day you could have a gear from a 70 and a 76 side by side and see the difference. By 1980, all replacement gears were produced with retarded cam timing. (This does NOT inlcuded performance manufacturers like Cloyes, Crane, etc) Again, spec out the Ram Air III 400.
Though I saw the articles on Pontiac valve adjustment, I would tend to disagree, since Pontiac is designed to tighten the nut against the thread bottoms of the studs, hence the reason for the 25 ft-lb of nut torque. One of the biggest drawbacks in their day was the pressed in studs that would work themselves up out of the head. Most shops would convert them to screw-in studs or dill and pin them to eliminate the issue. Valve train dimensions were specific and didn't have the broad tolerances of the small block Chevys. If you bottom out a lifter on a Pontiac, it's because one of the valve train componenets is out of spec, not because you misadjusted the lifters. On a smalll block Chevy, you could literally run a collapsed lifter down until the plunger bottomed out in the bore. Not a recommended practice, but it at least kept you from beating the rest of the valve train until you could replace it.
This site is not really good at sending notifications to my email, so it may be the last I hear of this. I'd really like to hear how things go for you when you're up and running again. Email me at thestaff "at" elderlyiron.com. If you'd like to see what we're doing with a pair fo 389 Ponticas, just search "This Old Truck" on YouTube. We're building one for a 57 GMC restoration project, and another was a junkyard haul that we're resurrecting "old school!"
Jeff
The Following User Says Thank You to Elderly Iron For This Useful Post:
raguza123 (09-13-2012)
Valve Lash jor Engine 17 09-16-2012 12:52 AM
I'm told to check the Ballast Resister... sscardino Engine 3 12-31-2011 02:37 PM
Valve lash badknuckles Hotrodding Basics 16 05-31-2011 03:54 PM
valve lash eclipse90108 Engine 0 07-26-2009 07:16 PM
valve lash??? chevyelc81 Engine 5 03-29-2009 07:25 PM
