Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Iwata air gunsa review
Old 12-09-2012, 02:05 PM
mitmaks's Avatar
mitmaks mitmaks is offline
Last journal entry: Grille
Originally Posted by deadbodyman View Post
actually, Ray the 1.3 tip is only good for clears that are reduced or med solid clears for the good high solid clears you need a 1.4(the thicker the material the bigger the tip) you cant atomize the material better if you cant get the material out of the gun,right? I use a Sata 1.3 for my base and reduced clear but when I use the good HS clears my Iwata 1.4 does the job best..
My Iwata has been in use for about 8 yrs and lately its giving me a little trouble ,its getting a little wore out so I've been looking to replace it I'll be going with a devilbis TECNA for around 450-500.00 it comes with three tips and sounds promising They'll be sending me a gun to demo and know I'll be comparing it to the Sata and Iwata and if it dont preform at least as well it'll be sent back...The man I talked too said he knows my guns well and has been painting for years and thinks I'll love this gun, to date hes only had one come back from a demo...Then I called my buddy Barry K and he said hes heard a lot of good things about these guns and nothing bad, so Im going for it and with any luck I'll be a devilbus fan again...I'll let yall know all about it after I spray a ca ror two
You could reduce thicker clear to help it flow out. I don't see any harm in using reducer with thicker clears even if it doesn't call for it.
