Iwata air gunsa review
Anyone used this gun before? How does it compare to others?
Iwata makes good guns. However I'd like to hear from someone who has used one.
One I'm looking at is 1.3 setup and they come in different setups 1.3-2.0. You can get one for $100 shipped. I'd just like to get a decent clear coat gun. I do have 2 sata Jets and they're just not perfect for clear (with 1.4 setup) and I'd just sell them |
Sata's are good clear guns depending on the model. Your 1.4 tip may be your problem...try a 1.3 for clear. If you use a heavy bodied clear it needs to be broken up more and you can achieve this with a smaller air cap and needle. All I use in my Sata's for clear is the 1.3 tip.
I still like the old Devilbus technology for clear as well, the GTI is an excellent choice for the heavy bodied clear coats. Ray |
Yes, sata's are nice. They just dump too much clear imo. I'm just not used to this gun yet. Seems like I need to bump up more pressure to atomize clear better but then I'm wasting a lot of clear in overspray. Then there's no whole HVLP point to it.
I love my Accuspray gun. Unfortunately they don't make them anymore, got bought out by 3M I believe.
Just try it. Ray |
By the time I buy needle, tip and air cap I might as well buy another gun lol
My Iwata has been in use for about 8 yrs and lately its giving me a little trouble ,its getting a little wore out so I've been looking to replace it I'll be going with a devilbis TECNA for around 450-500.00 it comes with three tips and sounds promising They'll be sending me a gun to demo and know I'll be comparing it to the Sata and Iwata and if it dont preform at least as well it'll be sent back...The man I talked too said he knows my guns well and has been painting for years and thinks I'll love this gun, to date hes only had one come back from a demo...Then I called my buddy Barry K and he said hes heard a lot of good things about these guns and nothing bad, so Im going for it and with any luck I'll be a devilbus fan again...I'll let yall know all about it after I spray a ca ror two |
Both the guy with the Demo TECNA and Barry K are right...The TECNA is an excellent gun...I'm sure your going to be happy with it. I've a TECNA them on several occasions and even sold quite a few...loved the guns and never had a complaint about them...I recently talked to a few old customer's of mine that I sild the gun to and they all agreed...a great gun.
Ray |
Where do I start...All clears use reducer...some clears have the reducer built into the clear and all you do is catalyze it. Adding extra reducer to clear can cause it to "die off" as the solvents come out. This doesn't happen all the time and is dependent on how much extra reducer you put in. If your using a clear that doesn't call for reducer and you add reducer to it, you need to aware that reducers come in different strengths, and using a reducer not designed for the clear your spraying can give you the dying off situation I mentioned.
"Deadbodyman", I agree with what you said to a point, that you can't atomize clear if you can't get it out of the gun. If your spraying a heavy bodied clear and your getting orange peel, a 1.4 tip is going to atomize less than a 1.3. I've never had a clear that I can't get out of the gun, I have had clear that is heavy bodied to the point that I got orange peel...I solved the problem (for the way I spray) by going to a 1.3 tip. I had to move slower but I got less orange peel because I got more atomization. Base coat, being a thin product, atomizes much easier and can be sprayed successfully with different tip combinations. A lot depends on spray technique and product. If a 1.4 tip works for you with heavy bodied clear, that's what you should use. For me, I like my 1.3 for heavy clear. |
Try this ....leave some good 1:1 clear in a mixing cup (about a 1/2" or so) Then take the same clear and reduce it 4:1:1 in another cup and let them both cure for a two weeks ....you'll find the reduced clear seperates form the cup about a 1/4" -1/2" and the unreduced clear will still be stuck to the sides....ever wonder why sand scratches show up after a few weeks ? I truely believe thats half of it right there... |
Your right again Dead. Sand scratches that show up a few weeks after painting is caused by the products both on top and underneath the paint shrinking. Say for example somebody finishes their body work in 80 grit..primes the repair area, doesn't leave proper flash times and then it gets prepped for paint. The painter paints the car and it looks great. A time goes by and sand scratches show up in the repaired area. Base coat is made up of pigment and in most cases solvent, (reducer), as I mentioned earlier all clear have a solvent or reducer in them, so again, you have another product with solvent going over top. These solvents go through the base coat, through the prime and right down to the metal and when they hit metal they bounce up and take remaining solvent left in the primer, base coat and clear coat with them...this action is what gives you chemical adhesion and is necessary for paint to stick. However, as it takes the solvent out, the substrate shrinks, as "Deadbodyman" described. When it shrinks, it leaves behind sand scratches. This is another reason why flash times are important as well as finishing body work with a finer paper. When body work is finished in a course paper, the primer fills the sand scratches, but, the primer in the footprint of the sand scratches doesn't "flash" properly and this is how you end up with scratches appearing even months after the car is painted.
Ray |
| The Iwata LH 1.4 400 Copy pics and review | BondoKing | Body - Exterior | 182 | 12-19-2012 08:42 PM |
| Air Compressor Review/Suggestions | hoffmandirt | Garage - Tools | 16 | 03-13-2012 01:24 AM |
| Tool Review Part 1. It's a two-for-one review.... | schnitz | Garage - Tools | 0 | 04-12-2009 06:57 PM |
| Iwata | DougMN | Body - Exterior | 10 | 01-26-2007 04:52 PM |
