Iwata Lph-400 (lv) ?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2005, 10:53 AM
rrmccabe's Avatar
GM Muscle
Is there a difference between a LPH-400 and LPH-400LV??
My jobber has a 400LV that they want to $420 for less cup. I really dont care about the cup as I am using the 3M PPS system.
I looked in Ebay and see LPH-400's in the $360 range with a cup. Is this the same gun?
Rich
Old 07-27-2005, 11:47 AM
rrmccabe's Avatar
GM Muscle
Geez, I figured this would be an easy one
It appears the LV is the low volume version which would be assumed but was not sure.
I called Iwata and did not get a real good feeling from the lady I talked too. (like she was reading out of a book)
But she said the LV was the low volume version.
So went ahead and bought one with the 3M collet for the PPS system.
Sure looks and feels nice Spays thinner nice too !
Rich
Old 07-27-2005, 12:19 PM
A link to ask questions about Iwata Products in an open forum format.
http://www.asetusa.com/phpBB2/index.php
I think you will like that Paint Gun.
Old 07-27-2005, 12:21 PM
rrmccabe's Avatar
GM Muscle
Like it..
Well I hope I dont use up all my thinner just playing before I get a chance to paint !! haha
Thanks
Old 07-27-2005, 03:16 PM
Last journal entry: metal finish
I got mine from my jobber for 350$ with an aluminum cup.. dont know why but he must of liked me that day.. i was about to buy it off ebay for 400 but i just asked him for kicks and i ended up buying it then and there.. works real nice i use it for kandys and clears..
Old 07-27-2005, 04:10 PM
rrmccabe's Avatar
GM Muscle
That was for the lv versison? Thats a bargain if so.
I think they are starting to show up on Ebay for the $360 range but not sure. I know the non lv versions are.
Rich
Old 07-29-2005, 06:55 AM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Sorry about the late post. Been VERY busy lately.
To my knowledge they are the same gun.
I paid 350 for mine too. My local supplier who I spend quite a bit of $$$ with over the years. Sometimes you have to "remind" them about your loyalty and some "initiative" is in order.
You get the 1.3 or 1.4 ?
I got the 1.3 and am pleased with it so far. I was having some 'peel and wasn't too happy with it till I did an OEM tailgate and set it on the truck and realized how much BETTER it looked than the OEM clear.
The transfer of material is better than what you think. I have not checked it with a mill guage but after color sanding a few pieces,noticed how thick the clear was with just 2 coats.
Old 07-29-2005, 08:20 PM
rrmccabe's Avatar
GM Muscle
Yea I really dont know. The Iwata person I talked to did not give me a warm fuzzy feeling that she knew what she was talking about.
She said LV was the low volume version. Look at yours and see what the Atomizing air pressure shows in the book. The LV is 16psi. I am going to try it at all pressures. Someone on the board that I have grown to trust told me not to be afraid to try 30psi.
I friend of mine is coming over tomorrow and wants me to reshoot his Mustang hood with silver Base/Clear. I am going to shoot the clear with the Iwata but have not made up my if I am going to shoot the base with it. Might use the Devilbiss gti for some and the Iwata for the rest. See how they compare.
And, I am also using the 1.3 tip.
Rich
Old 07-29-2005, 08:44 PM
Bee4Me's Avatar
30 Might be way too much IMO.
I am running at 20# at the gun reg. with 2 3/4 out on the fluid. This is with Nason Select clear at a 3:1. Approx. 7" from panel,going probbly 1' per sec.
It's laying a lot nicer than OEM 'peel but I know it can do better.
I'm used to a 1.4 and will get a tip for it shortly. I just am not pleased with the 1.3. On a laid down panel,yeah,It will flow perfect,Just haven't quite got the hang of a 1.3 on verticle.
I have several scrap pieces of metal from work to play with and will do some more testing on those.
It's always a learning curve with a new gun to get it right to the way YOU shoot. I won't conform to IT, IT will have to conform to ME.
I'm WAY ahead of the game with this gun and it IS a PLEASURE to use.
I'd do some test shoot's on junk metal just to get it figured out a little before you go for real on a keeper.
Old 07-29-2005, 09:03 PM
Yeah, I agree. And it takes considerably more time if you're not using the gun day in and day out like a full time painter. I did a complete last weekend with Global 894 clear and the gun was set near the top of the green on my regulator-about 38psi with three turns out on the fluid knob and a slightly decreased fan width and it layed the clear on like glass. Prior to this I was shooting in the 20 psi range with less fluid for smaller pieces and jambs, etc. I also did some with as little as 12 psi with the fluid knob choked and it works fine. Quite a few friends of mine are using this gun now and it's interesting to find they all like different settings, some shoot with 18 and others at the top of the scale 40ish. Different materials, different techniques? All I know is this gun rocks IMO, atomizes high solids clear way better than anything else I've ever used.
Old 07-29-2005, 09:22 PM
Bee4Me's Avatar
Wellll....
Might be something to that guy running 40 at the gun I refered to earlier.
I plan on giving it a work out this weekend from the "recomended" to the "extream"
I noticed that my Finex touch up which recomends 23# lay's very nice at 40.
Which is what my Harbor HVLP touch up is supposed to run at.
Old 07-29-2005, 09:44 PM
[QUOTE=Bee4Me]Wellll....
QUOTE]
, LOL, Yeah he might be right, I sure can't complain about the results I had at 38- each coat sprayed as smooth as glass. More overspray at this pressure though. The results I was getting at 20 were also damn good just much less material output and smaller sized pieces-less overspray also. Sure is interesting comparing notes.
Old 07-30-2005, 11:49 AM
Bee4Me's Avatar
Compairing notes with people who actually paint is always a GOOD thing. Main reason this site is stuck with me.
Could be that at the recomended psi,'peel is akin to OEM and "accectable" for Gov. regs and OEM's on repairs.
At 20#,it was better than OEM as I said, But It just drives me CRAZY to let something out that isn't slick.
Yeah, I'm myself but it's just not in me to do a half ***** job,which that is IMO.
BTW, White is a real B**** to buff out,
It was cloudy the day I did it and finaly got to see it in the sun and noticed I got some more buffing to do.
This was my first truely white job and it's hard to get the reflective aspect for buffing without a LOT of light.
Old 07-30-2005, 07:45 PM
rrmccabe's Avatar
GM Muscle
You know I have to wonder if the maximum recommended pressure has anything to do with being complient? Above that psi and it no longer meets spec.
As a hobbiest, its not something I am concerned about.
Just a thought?
Rich
Old 07-30-2005, 08:19 PM
Bee4Me's Avatar
Us "hobbiest" usually run outside the rule's anyway.
One reason our work excel's. We have the time and put the effort into small time projects. Main reason I would not want to do this for a living,It then becomes a "JOB" which I already have,and would take all the appreciation out of it.
It was fun,and it was real, but it wasn't REAL FUN. Which this IS to ME. I finally found a flame design tonight that is "different" and will expound on it to fully realize MY style. Coloring outside the lines is what I excel at and it bite's me most day's.But tonight,I bit IT square in the A**.
I have been searching for a flame layout that appealed to ME from the normal Classic,Tribal,Gothic,Ect. It's a free flowing design and will take time to perfect but main thing is, I LIKE IT. Let you know.
Tomorrow, I'm testing the LPH and will get back with the results.
BTW. Teal HOK KK is a KILLER color. I picked up some Fri. and got to shoot some tonight over a silver base and it is one of the most BEAUTIFUL color's I've shot. Tangerine is a close second but that Teal is AWSOME.
Ok, here's the debate of the century: 383 or 400 chevy!! Cast your vote and reason killerformula Engine 303 03-28-2013 08:08 PM
The Iwata LH 1.4 400 Copy pics and review BondoKing Body - Exterior 182 12-19-2012 08:42 PM
400 Combinations MI2600 Engine 15 05-12-2006 07:08 PM
chevy 400 buildup 406chevelle Engine 15 06-08-2003 03:41 PM
400 327 crank limey Engine 8 09-24-2002 07:53 AM
