iwata lph400 paint cup - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2011, 01:51 PM
i bought an Iwata lph400 spray gun & it didn't come with a paint cup. what size do you use & what would you suggest? i can get a 600ml, 700ml, or 1000ml cup, I'm just not sure what to get. also is there a cheaper alternative than using an Iwata cup? just the cups are around $50.00. any advice?
Old 12-17-2011, 02:19 PM
shine's Avatar
Last journal entry: some progress
i use the aluminum 700 and also use the disposable plastic ones.
Old 12-17-2011, 02:51 PM
Irelands child's Avatar
I have the 1000 and while it is balanced, I would have preferred the 6 or 700. When you get low, the 1000cc is a bit unwieldy
Old 12-22-2011, 06:38 AM
I think the guns come with a 3M adapter to use their cups. You may ask about them. I really like using the PPS. Here is a video about how to use these cups. [URL=http://********************* [/URL]
I like to use this system because you can spray upside down or any angle.
Last edited by poncho62; 03-21-2012 at 05:18 PM. Reason: Advertising. Please see: commercial posting guidelines.
IWATA LPH400-LV HVLP SPRAY GUN 1.3 tip thunderhead Body - Exterior 45 11-03-2012 06:17 PM
i bought an iwata LPH400-LVX the nitro man Body - Exterior 2 12-03-2011 04:45 PM
Need help with buying Iwata LPH400 impalass Body - Exterior 1 05-17-2009 09:11 AM
Iwata LPH400 Gun Setting gto3 Body - Exterior 11 10-26-2008 09:10 AM
Iwata LPH400 w/Sikkens schatzy Body - Exterior 14 08-15-2007 09:02 PM
