Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Iwata LPH400 w/Sikkens
Old 08-09-2007, 10:23 PM
BondoKing's Avatar
BondoKing BondoKing is offline
KING OF BONDO
Last journal entry: My little helper
Originally Posted by schatzy
Hello all, I was wondering if anyone is using the Iwata LPH-400 with Sikkens? The shop I work at is using Autoclear III and I am having a hard time to get the clear to lay like I think it should. What are your settings/technique? I have the fan, fluid, and internal reg in the full open position. Air pressure is set at 20 psi on the reg on the gun. I am getting the thick and wavy look. Thanks in advance.
Don
Schatzy my man, sounds like you need some work in the gun settings department to start.. Check this Setup
and a couple threads just regarding Iwata lph 400's
Gun Review
More reviews and tip selection
Plus the Iwata forum here Iwata Board
