Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Iwata paint gun
Thread: Iwata paint gun
Old 01-26-2013, 05:47 AM
mr4speed mr4speed is offline
On the recoat time 24 hours should be suffient with the s/s. And spraying at that temp I would use the fastest reducer you can get, also go double if not triple on your flash times. The colder temps it will take longer to flash even with the fast reducer. That could be the reason for the runs and the sovlent pop. As far as what you should go for as a reduction, that is something you are going to have to play with (on a test panel) to see where you are comfortable with what percentage of a reduced mix that sprays out the best in your temp range. Usually 5 -10 percent.
