Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Iwata paint gun
Thread: Iwata paint gun
Old 01-30-2013, 05:26 AM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
Originally Posted by benchracer1 View Post
I began sanding the fenders today and found a couple of edges that needed a little bit of attention. I sanded the filler and expose a couple small areas. I have a couple more small spots to do. I really dont want to spray the whole fenders with sealer again mainly due to the fact that it will be alot of material on the fender. Can I just lightly prime the affected areas and then sand and put the additional color coats. The picture is an area about 1 or 2 inches long.
I would recommend that you don't seal or prime the entire fender, prime the areas that you are concerned about, prep them with your finish grit of paper. If your spraying single stage (I can't remember if it was base coat or single stage), I would recommend that you prep the entire fender and put color on the entire fender. If it's base coat, same procedure but you wouldn't need to put color on the whole fender, just prime, prep the affected areas, blend your color and clear the entire fender.
Hope this helps.
Ray
