Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Iwata paint gun
Thread: Iwata paint gun
  #18 (permalink)
Old 02-03-2013, 09:14 AM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
I re-read the thread trying to find out if it was single stage metallic or solid color you sprayed...if it's a metallic color,sanding and polishing is not an option...as you sand for polishing you will knock the tops of the metallic's and that can't be polished.
If what you sprayed is a solid color single stage any good quality, non silicone polish would be recommended, Meguier's, 3M, Mother's etc. You should have enough material to polish, it sounds like you put on a bout 4 coats after the last re-do...if you wanted to you could put another two coats on without a problem...any more and your getting a bit to much mil thickness.
Ray
