I went ahead and sprayed the paint today and for the most part came out well. I did however end up with a couple of runs. How long do you generally wait to wet sand and recoat single stage acrylic urethane. A little color sanding and 1 coat and it should be fine. Temp when I sprayed was 62. A little cool i guess.
On the recoat time 24 hours should be suffient with the s/s. And spraying at that temp I would use the fastest reducer you can get, also go double if not triple on your flash times. The colder temps it will take longer to flash even with the fast reducer. That could be the reason for the runs and the sovlent pop. As far as what you should go for as a reduction, that is something you are going to have to play with (on a test panel) to see where you are comfortable with what percentage of a reduced mix that sprays out the best in your temp range. Usually 5 -10 percent.
With respect to solvent popping...what are you using for an exhaust fan?...and did the the top panels pop and the where the sides OK? Solvent popping is often caused by the top of the paint you sprayed skimming over due to too much air moving over the car. If you the paint does skim over, the solvents left underneath the paint are still trying to get out and causing a volcano effect (or solvent pop) when they do finally get out. If your air flow is OK, the speed of your solvent (reducer) or hardner can also have a bearing on solvent popping.
A little more information about your location would be the most help Ramona could be in the middle of alaska, on top of a mountain in Bolivia, in a swamp in Brazil, you get the picture?
I'm not a paint expert by any means, but around here Ive found I have to wait at least a week before touching single stage in this ultra humid climate., even the body shops where they have fancy spray and cure facilities, I ended up waiting almost 2 weeks on a hood one time in real moist weather for them to get 2 good coats on it , now if youre in the desert, its a different story Needless to say, i wont fool with the stuff unless the car already has it and its just a repair. because Im working outside, and having to wait a week or more to sand the inevetable bugs that land in it out is enough to drive you insane. |
sorry, fixed that in my profile. Its outside san diego, ca. I dont have an exhaust fan just the prevailing breeze. The panels i sprayed were actually vw fenders. I think it was alittle cool and light rain and I did not give it enough time between coats. I am going to let the fenders sit for a week and spray the rest of the car later this week. Ill be a little more careful of btween coat times. I ll post the results....steve
It's usually a good idea to slow things down a bit if experience isn't on your side...read and understand the tech sheets and choose the right hardner and reducer for the climate your spraying in. Let us know how you make out.
Ray |
When I sand and repaint, I give it two coats...it's much easier to get an even, flat and glossy finish this way as compared to trying to lay down one wet coat trying to achieve the same results.
Ray |
I began sanding the fenders today and found a couple of edges that needed a little bit of attention. I sanded the filler and expose a couple small areas. I have a couple more small spots to do. I really dont want to spray the whole fenders with sealer again mainly due to the fact that it will be alot of material on the fender. Can I just lightly prime the affected areas and then sand and put the additional color coats. The picture is an area about 1 or 2 inches long.
Hope this helps. Ray |
That is what I was hoping to hear. It is a single stage. I knocked down the runs sucsesfully. After I prime and prep the area would it be a good idea to put a light tack coat of color to hide the prime then shoot 2 coats of color over the entire fender or just shoot the 2 coats and dont worry about it....Steve
It's a matter o preference, a light tack coat doesn't hurt...some people say you have less chance of getting runs...but two medium wet coats after a tack coat is fine.
Ray |
| Anest/Iwata W71 gun | cyclopsblown34 | Body - Exterior | 7 | 10-11-2011 07:56 AM |
| Pratco paint gun(Iwata W-77) | Slickriffs | Body - Exterior | 1 | 05-23-2009 09:08 AM |
| Iwata LPH400 Gun Setting | gto3 | Body - Exterior | 11 | 10-26-2008 09:10 AM |
| iwata extreme basecoat gun | mikelamb22 | Body - Exterior | 0 | 01-18-2008 01:01 AM |
| Iwata spray gun questions | Boop Coupe | Body - Exterior | 4 | 02-17-2007 10:42 PM |
