jag front end - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2011, 12:43 AM
jag front end
Just bought a 30's rod with a mid 80s jag front end. This car needs to be lowered about 2" in front. Anybody know if there are aftermarket dropped spindles for these or do I have to just cut the coils?
Old 01-15-2011, 08:06 AM
Wiki Edits: 27
jag front susp
Jags are popular in the UK and down under,, NZ and Australia. K & K Custom crosmembers sells a custom Jag crosmember , google them. Kevin is now on his own building them, HE changes the geometry and uses coilovers. they look good. the stock jag with the canted upper arms just don't look right on an open wheeler, The Keven redesign is closer the the Mustang II angles that everyone says handles best. with a new crosmember you could set the ride height where you want. For information on how to install a front suspension kit check the welder series info... they do mustang II but the guidelines still work for any suspension. I've got a couple of J 40 late 80's that are different that some day will be under a couple roadsters.
34 Ford chassis w/MII front end - front tires rub heyjude076 General Rodding Tech 4 04-09-2009 08:46 PM
Front frame / Front crossmember blueprints - feedback needed lowROLLERchevy Suspension - Brakes - Steering 2 09-20-2008 06:46 PM
making front drum into front disc.....? barbiekiller Suspension - Brakes - Steering 3 05-01-2007 06:57 PM
Front Suspension 53 Ford Front Clip PaulNJ53Ford Suspension - Brakes - Steering 2 08-11-2004 11:12 PM
front end tilt using my all steel front end old c10 head Body - Exterior 5 05-02-2003 02:45 PM
