Jag irs radius rods - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2008, 02:54 PM
Jag irs radius rods
Hi lads , i think i may have f***ed up , with my chassis build , i have been reading mixed thoughts on the location and angle of the radius rods when solid mounting a jag rear end .
Some say that they should follow the inner fulcrum mounting point forward on the same axis to prevent binding which i can understand, others say they can extend straight forward as long as they are long enough which i can also understand, and the rest say they are not needed at all !
i have fitted mine using poly bushes both ends straight forward extending approx 50" . should i change these to match the inner fulcrum axis before i have the chassis painted ? obviosly i want to address this if nessecary before any color goes on it !
the full suspension travel on the rear is only approx 4" on air ,so will the radius rod actually pull the lower arm about at all?
Your opinions would be appreciated i have 4 weeks to sort it before paint
Cheers ASH
Old 04-15-2008, 12:44 PM
staleg's Avatar
Last journal entry: Home made gear stick
I'm building a '34 roadster with Jaguar rear.
From what I've read and heard the first alternative you describe is the best, the solution you have choosen is the second-best.
And if there still are d*** a**** out there that still say loud that the radius rods are not needed, well I suppose that then will count in as the third best (or better described: worst) way to do it.
Old 04-15-2008, 04:02 PM
Jag rear
Hi mate cheers for your reply, thats what i thought to be honest , the full suspension on my chev is only about 4" between raise/ride/park ,if i take a strip of wood clamp it against the radius rod upright and then move the rod up and down 2" each way from ride height centre mark the arc gap is about 1mm top and bottom and seen as my rods are polybushed front and rear i dont expect this to be a problem (fingers crossed) , i dont seem to get any binding over this travel so all should be good .
Nice looking chassis by the way , jag is the way to go even if people have been usin them for years , they seem to be quite hard to beat !
regards ASH
Old 04-16-2008, 12:20 AM
staleg's Avatar
Hi there!
And don't forget to set the Jag' IRS up with the drive shafts parallell to the ground.
Some set it up with the lower trailing arms parallell. Then the drive shafts will point slightly upwards from center and out. That mess up the intended geometry on the Jag' IRS.
During the build of my '34 chassis I have browsed lot's of GB Cobra Kit car forums. I find the British Cobra guys very knowledgeable about the Jag' IRS and focused on road handling rather than finned differential covers & bling bling stuff and that's closer to the theme of my '34.
Cheers from Norway!
Old 04-16-2008, 12:41 AM
jag irs
Cheers Staleg, i didnt know that ,but will put it into practice,good luck with ya build ,ASH
Jag IRS Width XNTRCI-T Transmission - Rearend 1 01-08-2007 02:04 PM
independent rear suspension truckboy Suspension - Brakes - Steering 6 05-25-2006 11:33 AM
5.7 rods in 400 joefromcocomo Engine 9 02-05-2004 11:59 AM
new rods or old rods? Blob Engine 12 02-03-2004 04:35 PM
Forged Rods and Pistons for Ford 302? Mustang 69 Chile Engine 6 10-21-2002 06:39 PM
