bird irs
Factory Five has the ford IRS optional on some of their kit cars, Cobra replica's > I saw a bird IRS in a T bucket at a car show about 5 years ago, the guy said he was going to Fab up tubular arms, clean up the look but haven't seen anything for sale yet. The Jag is faster and easier to set up. CCR has their T bucket plans , the Jag pages are only $ 5 for the set. I used the scanner plasma at the college and my parts were distorted, it could have been the copier . Next time I will use the CCr plans and my drafting tools to make the white cardboard pattern to make the next set of parts.
whats the latest on the build?
jag stuff
We picked up two more jag fronts and rear when the snow melted for a couple of days, Jag uses 2 different steering shaft-u joint systems , one is smaller if you have clearance problems, we also got the brake booster pedal and master Cyl , one has a 4 way dist block, the other is just hard lined to front and rear. Stitch's fab work corrects some of the mush ride of a Jag rear, the stock jag arms need to mount low and don't look right on trucks or highboy's.
jag stuff
The reason the control arms are as long as mine are is that the fulcrum point on the lower A arm has to be in line with the pivot pivot point of the control arm this allows the unit to work like a big A arm, and relieves any binding
| Jag Rear End Advice | farna | Transmission - Rearend | 3 | 06-13-2003 06:52 PM |
| Diff temp gauge for Jag rear end | Jag Daddy | Transmission - Rearend | 0 | 05-09-2003 05:36 PM |
| Jag Rear Axle -- almost completed! | farna | Transmission - Rearend | 5 | 02-28-2003 07:55 AM |
| Rear end swap for '53 Chevy truck | Bruce H | Transmission - Rearend | 4 | 12-01-2002 11:43 AM |
| transmission rear end for 65 chevy truck | shortwide65 | Transmission - Rearend | 0 | 05-28-2002 08:37 AM |
