jag rear suspention for chevy truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2009, 06:11 PM
would like some info on jag rear suspension for my 56 pick up
I just installed a jag front end and that came out great
would like to try for the rear any info would be appreciated
Old 09-01-2009, 06:16 PM
Wiki Edits: 27
jag rear
If you use the jag crosmember-cage it should be easy. My son has a 350-350 in his 22 dodge bucket and he found a drive shaft in the parts pile that fit both ends. It wasn't marked so we have no idea what i tcame out of . just had to cut it to length, no expensive pieces to buy. If you want the open look there are crosmembers and kits you can buy. I think Concourse West in oregon has a lot of parts wou will want.
Old 09-01-2009, 10:25 PM
Wiki Edits: 27
more jag rear info
go to the tbucketeers web site and search for jaguar rear . allot of the T buckets us the jag stuff,,, some picts and good info
Old 01-13-2010, 12:29 PM
jag rear end
Since my last post I have done some work on my 56 chevy pick up
check out my progress
stich.
ID:	43205   Click image for larger version
ID:	43206   Click image for larger version
ID:	43207   Click image for larger version
Old 01-29-2010, 04:24 PM
I have a 51 FORD F1 & i want to put a jag IFS in it & i heard that
it was a easy installation .How much trouble was it & do you
have any pictures of the installation that you could share with us ?
Old 01-29-2010, 09:24 PM
All I know is that adding Jaguar parts to anything will usually cause oil leaks and electrical problems.
Old 01-29-2010, 09:37 PM
Wiki Edits: 27
jag
K and k custom crosmembers have a good looking kit for using xj6 front parts. I looks like they change the geometry a little bit. K and K looks good on open wheel cars. for a full fendered truck you should be able to use the stock X member. those swaps are popular in England. CCR sells plans for T buckets. I copied the jag pages and laminated with clear shelf paper for the shop copy. I don't know if the copier distorted them but the college electric eye plasma followed the patern and they weren't symetrical side to side I have a couple of later series jag front susp in the shop and I plan on doing something similar to the K & K design.
Old 01-29-2010, 09:48 PM
Wiki Edits: 27
stitch, look s good
the old ccr plans uses clevis and heim ehds and the center section bolts on solid. Stitch used a lot of rubber bushings so he should have a very good and quite ride, The old xke racers didn't like the rubber mounts in the stock jag setup , It had too much movement for hard road racing.
Old 01-30-2010, 03:29 PM
ogre's Avatar
the 'Duracell Project'
nice work stich. you should check out the 55-59 chevy truck thread on this forum.
Old 02-06-2010, 07:39 PM
Jag ifs
Mercury man
The ifs in my truck was a slick install, my frame had been altered prior to my buying the truck so it was a little harder. the measurement for the front is 26 3/4 inside front mount to inside front mount. if your frame is smaller or larger you will have to make offset hangers. clearance on the frame rail to the top of the front rubber mount is about 1/2 inch. the jag crossmember should measure the same front to back off the floor when at ride height.
ID:	43760   Click image for larger version
ID:	43761   Click image for larger version
ID:	43762   Click image for larger version
ID:	43763   Click image for larger version
Old 01-23-2011, 06:12 AM
info
Seeking information on the instalation of the jag rear axle for my 57 chevy truck .... help me? thanks
Old 01-23-2011, 06:34 AM
Wiki Edits: 27
jag front and rear
My son has a 46 international truck. we had been checking out doing a disc brake conversion . pulling a couple of spring leafs We were at a wrecking yard last week and the guy said he would sell jag fronts and rears for $ 100 each. When the snow melts a little we will go that route. We googled Jag suspension and there are a lot of different sites that have a lot of information.
Old 01-23-2011, 06:40 AM
I saw that Stich has already done this work ... and I thought it was easy for him to give me information
Old 01-23-2011, 08:04 AM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
89 up Thunder birds had independent rear suspension. Why arent they being used instead? The 8.8 rear is a goodie. American made. What gives?
My 93 had rear discs also. Sounds like a no brainer to me.JMHO
Also the jag front that is pictured looks like it weighs a ton
Old 01-23-2011, 08:45 PM
The Jag rear is also made in the US, by Dana, the same company that makes the 8.8 A Tbird rear is much harder to mount, a Jag in the original cage needs 6 bolts to mount it. A new Mustang IRS is a neat piece, and also mounts in a cage with 6 bolts.
A Jag front end weighs about 200 lbs complete. Most of it is aluminum.
Jag Rear End Advice farna Transmission - Rearend 3 06-13-2003 06:52 PM
Diff temp gauge for Jag rear end Jag Daddy Transmission - Rearend 0 05-09-2003 05:36 PM
Jag Rear Axle -- almost completed! farna Transmission - Rearend 5 02-28-2003 07:55 AM
Rear end swap for '53 Chevy truck Bruce H Transmission - Rearend 4 12-01-2002 11:43 AM
transmission rear end for 65 chevy truck shortwide65 Transmission - Rearend 0 05-28-2002 08:37 AM
