Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Jag XJ6 IFS install on 40's Chevy
Old 05-19-2010, 08:08 AM
40ChevyJim 40ChevyJim is offline
From the research that I have found, it appears to be be a very good option. As long as it is installed with everything being level, starting with the frame, then it is almost a bolt on. It looks like you have to fab a couple of mounts, depending on your application, but outside of that it looks like a much more affordable solution. I am in the same boat. Money is money! Parts are cheap and easily obtainable and you end up with a power rack, and the steering is in the right place! From what I see, it sure looks like the way to go. Good luck with your project and thanks. Sometimes you just need to bounce your ideas around!
