Jaguar Rear In 34 Plymouth - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2008, 01:54 PM
Appreciate Any Advice On Rear Brake Upgrades For A Jag Rear End. Thanks
Old 10-21-2008, 03:17 AM
staleg's Avatar
Last journal entry: Hand brake
Aren't the stock ones good enough? Even the kit car Cobra guys sticks to them. They are easy to rebuild and have the e-brake included...
Old 10-22-2008, 10:48 PM
31 hemi dodge's Avatar
Jag rear
installing a XJ6 rear in a 31 Dodge 3w cpe- any advice/ ideas ?
Old 10-22-2008, 11:14 PM
Wiki Edits: 27
how's the width
The xj's are wider that most other rear ends. are you going to install the cage or fab new parts. CCR has plans for $5 on installing the jag's in T buckets. one problem we had was getting everything tack welded and in alignment. next time I will have every thing bolted to the brackets before tacking then to the crosmember. I think concourse west in oregon has brake upgrade kits
Old 10-23-2008, 04:09 AM
staleg's Avatar
I'm using a non narrowed xj jag rear on my '34 Ford. works fine with the backspacing on the BMW 16x9" rims & 295/50-16 tires.
I tried the more narrow E-type axle first, but it was too narrow for my car/tire combo. Would have had to use massive spacers and that's not a good thing.
bolt pattern on BMW series is 5x120 mm, Jaguar/Chevy bolt pattern is 5x4 3/4 (same as 5x 120,6 mm)
The 0,6 mm difference is no problem (0,6mm = 0,024")
Old 10-23-2008, 04:12 AM
staleg's Avatar
Here are som more photos of the installation to give you som ideas:
Old 10-23-2008, 08:58 PM
Wiki Edits: 27
Staleg, looks good
Staleg, are you using only two stock springs ?. My son has all four and it.s way too stiff in his 22 dodge bucket lakester. I plan on using xj rears in my 32 ford project and the 29 nash roadster, I also have two fronts suspensions out of the later jag sedans. The ones that moved the brakes out to the wheels. I like the looks better on the fronts and will use gm caviliar rack for steering..
Old 10-24-2008, 07:30 AM
staleg's Avatar
I will be using 4 coilovers, but not the stock ones. They are way too stiff for a hot rod.
Old 10-24-2008, 08:16 AM
Tim34FSD's Avatar
Rear shocks
Staleg, What rear coilovers did you decide to go with? I will be after some shortly for my E-type rear set up?
Where can I fnd a disc brake kit for jaguar rear end Larry Tyner Suspension - Brakes - Steering 8 01-08-2010 02:50 PM
Auto Trans for '34 Plymouth rough_idle Transmission - Rearend 1 08-07-2008 11:36 AM
jaguar rear end somewt Transmission - Rearend 1 01-14-2008 09:04 AM
Opinions Please! 30 Plymouth Rear Fenders 1930u Body - Exterior 9 10-02-2007 01:40 PM
Help I Need 1930 Plymouth Fiberglass Rear Fenders 1930u Body - Exterior 1 06-23-2007 10:59 AM
