Jaguar Rear End - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2005, 12:43 PM
Jaguar Rear End
I am going to be rebuilding a 1989 Jaguar XJS rear end. Before I order a new differential i need to clarify a few things. I have read that a Dana 44 or a Dana 35 will work with a special mounting kit and a different coupler for the driveshaft. I called Randys Rack and Pinion and they said there are a bunch of variations in the Jaguar units that make a Dana 44 tricky. Can anyone help?
Old 06-08-2005, 04:31 PM
gator412's Avatar
1955 2nd series Chevy Pick Up
Last journal entry: Body work and U bolts
I posted a question about a jag rear end also...at least I got one response. Seems that they are not as popular as they used to be, I guess from the response or lack there of. Good luck on your project.
Old 06-08-2005, 06:56 PM
mj_lover's Avatar
expert lurker
Last journal entry: day one!
query, how much horsepower are you going to run? the d35 isn't the strongest dif out there. its something to keep in mind
1988 Jeep comanche 4.0L
1991 5.0L explorer
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Thump Thump in rear end?? HotRodMan Suspension - Brakes - Steering 7 01-24-2007 06:09 PM
S-10/Camaro Rear End slaveforthewave Transmission - Rearend 7 02-20-2006 01:44 PM
dodge challenger in need of rear end advice. Journier Transmission - Rearend 0 05-28-2004 10:23 PM
Ford 7.5" Rear End Traction-Loc Install nightrain_rod Transmission - Rearend 2 12-30-2003 06:38 PM
