jaguar rear suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2009, 11:48 PM
Does anyone know where I can get parts for my jag rear end. It is going in a 34' Ford Coupe.
Thank You,
Thomas
Old 02-12-2009, 12:31 AM
Docc's Avatar
Dry Heat
Last journal entry: along the weird tale..
What parts do you need ? Bushings..or hard parts ? Everything is available. What year is your Jag unit ?
Old 02-12-2009, 06:50 AM
woodz428's Avatar
Troll Hunter
If you go to the Cobra forum (Clubcobra), there are several replicas that use this rear suspension and you can probably get a lot of sources from them.
Jaguar independent rear suspension specs Luxobarge Suspension - Brakes - Steering 19 06-20-2012 06:19 PM
Effects Of Offset Driveshaft On Rear Suspension Geometry toddshotrods Suspension - Brakes - Steering 15 04-20-2009 06:39 AM
Rear suspension suggestions ProCobraII Suspension - Brakes - Steering 3 09-19-2007 07:35 AM
Narrowing a '73 GM B-body Front and Rear Suspension hduff Suspension - Brakes - Steering 2 09-09-2007 08:56 AM
Help...rear suspension design questions FrankR Suspension - Brakes - Steering 1 06-02-2006 07:50 PM
