In a Jamb - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2013, 02:42 PM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
In a Jamb
Sometimes it's hard to use a block!
This one is kind of interesting, not to much
for a straight block.
I'm still working on the door.
ID:	74008   Click image for larger version
ID:	74009   Click image for larger version
ID:	74010   Click image for larger version
ID:	74011   Click image for larger version
Old 05-14-2013, 07:58 PM
Looks good Jim, don't those little quarter panels crack you up? God what a difference from when I got into this business. A quarter panel on the average car of the day would have enough metal to skin the doors and the quarter easy!
Old 05-15-2013, 12:08 AM
put up or shut up
nice. did you use a quarter panel puller on that?
Old 05-15-2013, 05:54 AM
jcclark's Avatar
The Penny Pincher
I used my old puller that has a hook on it & I had to drill holes
to use it. My stud welder wasn't strong enough.
I welded the holes close afterwards.
Brian: yeah, those qtr's are cute!!!
Here's the door. I sprayed G2 poly over it all, blocked it,
then 2K, blocked w/ 150 grit, then 2K again and final 600 grit.
May be overkill but I waned it straight.
It's my daughters car so it's going to be better done
and no money for it. I told her it's her birthday present,
that's near.
ID:	74025   Click image for larger version
ID:	74026   Click image for larger version
ID:	74027   Click image for larger version
The Following User Says Thank You to jcclark For This Useful Post:
mitmaks (05-18-2013)
Old 05-22-2013, 05:47 AM
jcclark's Avatar
The Penny Pincher
Well, it's done.
Took me longer than usual due to some health problems,
but I'm back and ready for the next one.
There's always a "next one" (LOL)
ID:	74214   Click image for larger version
ID:	74215   Click image for larger version
ID:	74216   Click image for larger version
Old 05-22-2013, 08:33 AM
Beautiful Jim and excellent pictures, it REALLY shows how nice it is which you have to WANT TO capture in a photo, beautiful.
BRian
Old 05-22-2013, 09:06 AM
put up or shut up
blend the front door? looks like it has good flop.
Old 05-22-2013, 09:50 AM
Beautiful work as always; is that a SSU or a BC/CC? And, how far did you blend it out?
Old 05-22-2013, 12:02 PM
jcclark's Avatar
The Penny Pincher
It's base/clear, that's all I use in repair work.
I put a few coats to cover the door first then
pulled the masking and sprayed the door again while blending half
ways into the front door and rear Qtr.
I've been using a base by "Metalux" and getting really
good matches with it.
Brian: Thanks, coming from you, it means a lot.
I have upped my quality a lot by forcing myself to coarse sand my
primers first before finish sanding.
My panels are coming out much straighter than ever before.
ID:	74226   Click image for larger version
tech69 (05-22-2013)
Old 05-23-2013, 10:06 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
Amazing work, thanks for sharing! I would have never guessed it's been hit or the paint blended by the "after" pics.
Door Jamb Jeff13 Body - Exterior 0 01-22-2013 07:08 PM
Door jamb connectors? ScotY Electrical 7 06-03-2009 06:58 PM
door jamb contacts - 37 ford adcox Electrical 0 02-13-2009 08:50 PM
To Jamb or Not to Jamb Ron M Body - Exterior 5 08-17-2004 09:01 AM
using a jamb nut for rocker adjustment nuts Dubz Engine 4 07-19-2004 04:31 PM
