Jambing??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2009, 11:49 AM
Jambing???
Can someone go over the basics of jambing / cutting in body panels. My plan is to pull all the panels off, sand, epoxy prime and paint jambs, reassemble, then paint entire car. This sound right? If I'm not looking for a perfect surface, can the surface just be scuffed with Scoth-Brite and epoxy primed? I'm planning on doing all the priming and jambing myself, and letting someone else paint the entire car. I'll just have to find out what kind of paint they're using, and jamb with this, right? Thanks for any advice.
Jamie
Old 03-16-2009, 06:42 AM
Is a Scotch brite pad okay for the jambs? What color/grit/grade?
Jamie
