Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Jambing
Thread: Jambing
Old 11-17-2012, 05:42 AM
mr4speed mr4speed is offline
I have done plenty of metallics apart without any vary at all. Have even shot the doors laying down a few times, instead of hanging them the way they would end up on the car. Now if your shooting a tri stage metallic that is a different story, would not shoot that apart because of too many variations with the mid coat. But if it is just a straight base clear all coming from the same mix, should not be an issue. Just as long as you spray beyond all your panels making sure you have full 3 coat coverage and don't end up with light coats toward your edges. On the very tough light metallics I will even go a fourth drop coat.
