Originally Posted by abarli65
Does anyone jamb the window channels?
I have a 65 mustang coupe almost ready for paint and I am contemplating how to go about it... If I were to paint the jambs and cut the fenders, could I also paint the window channels and then drop in the headliner and glass prior to spraying the entire car?
I imagine I can just tape off around the channels, lay down the bc/cc, then after the glass drops in, tape off the glass and rubber and scuff as deep as I can. would I have any lifting issues once I spray the car? I would not be concerned with lines since I would caulk and then cover with the window frame pieces.
I have been searching and have not been able to find any pictures or methods that cover this detail.
I have “hobby” painted many early Mustangs; I would not jamb the window frame at all. Install your headliner, then the windshield and back glass. Just mask the glass and rubber and scuff around the edges prior to painting. You will not have any lifting issues. Install the trim moldings after you paint.
